ChimpyGlassman
Message 1 of 5
bt Infinity ESTIMATED 56-76 MBPS GETTING LESS THAN 17
Hi guys -
I have recently moved house and gotten Infinity at my new property.
I rang BT to swap the infinity from my previous property and they convinced me to upgrade to the 56+ package (which I though was pretty good!).
It turns out however, my speed are appauling.
I'm getting less than 17 mbps and have been for around 2 months.
The estimated speeds in my area are for 56 - 76 mbps but I have NEVER been anywhere even close to approaching half of that.
If I ring BT are they able to do anything? I think paying for a service that estimates I should be getting 4 x what I currently am, is pretty much fraudulent.
4 REPLIES 4
john46
Message 2 of 5
Re: bt Infinity ESTIMATED 56-76 MBPS GETTING LESS THAN 17
If you use this checker it will tell what cabinet you are on and what services it can receive. please post back the results editing out your phone number
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
ChimpyGlassman
Message 3 of 5
gg30340
Message 4 of 5
Your estimated speeds are anywhere between 38.4Mbps of the Range B line and 74.3Mbps of the Range A line. As you are getting far below even the lowest estimate you need to contact BT and report a fault and request an engineer out to investigate where the fault is.
ChimpyGlassman
Message 5 of 5
Cheers buddy.
Will give them a ring when I get in.
