worthog567
Message 1 of 4
bt cloud
i have installed bt cloud and should have 50gb but only got 5gb i have infinity2 unlimited does anyone no why this is any help would be appreciated thanks
3 REPLIES 3
NeilO
Moderator
Moderator
Message 2 of 4
Re: bt cloud
Hi worthog567,
Please use the 'contact the mods' link in my forum profile under the 'about me' section to send in your details and we'll get your cloud storage size sorted. You can find the link by clicking on my username.
Cheers
Neil
worthog567
Message 3 of 4
Re: bt cloud
thanks for your response i have emailed the details to you.thanks
worthog567
Message 4 of 4
Re: bt cloud
cheers david i will get that sorted out.thanks
