cw182
Message 1 of 59
bt declined topcashback
Both me and my mother have done an order through TCB, one hasn't tracked and the other has been declined. We both only went with BT due to this. Had problems with the order as it kept failing and BT had to do something at their end. We did did it through TCB. Can someone help?
58 REPLIES 58
DavidM
Moderator
Moderator
Message 2 of 59
Re: bt declined topcashback
Hi @cw182 and thanks for posting.
Were there problems with both orders? Did you clear cookies and cache before placing the orders?
Cheers
David
cw182
Message 3 of 59
Yeah, mothers was sorted out pretty quickly. Mine is a bit more messy.
I just placed my order through topcashback the same way I have always done.
DavidM
Moderator
Moderator
Message 4 of 59
Can you confirm the first 3 letters of your order reference @cw182?
Cheers
David
cw182
Message 5 of 59
Thanks for your quick response with this. Both started with AJM.
DavidM
Moderator
Moderator
Message 6 of 59
Thanks for confirming that @cw182.
Can you drop me over an email with the details? You'll get the contact the moderators link in my profile.
Cheers
David
cw182
Message 7 of 59
thanks for the response. i am a new user however no excuse for being thick. I have gone onto your profile but cant see any link:/. I have logged in but still cant see anything:(
DavidM
Moderator
Moderator
Message 8 of 59
My fault @cw182 Smiley Embarassed. You should be able to see the link now.
Cheers
David
DavidM
Moderator
Moderator
Message 9 of 59
Hi @cw182,
I picked up your email, thanks for sending over the details. I tried calling, sorry I missed you. I can see the cashback claim is in hand for your account and your case handler is due to get back to you soon. I've opened a case on your mums account and I'll call again tomorrow to discuss further.
Cheers
David
DavidM
Moderator
Moderator
Message 10 of 59
Hi @cw182,
I tried calling this morning, sorry I missed you. I'll try again tomorrow. Did you open a dispute with Top Cashback about the offer? If not then you'll need to do so before we can investigate this for you. Once you open a dispute you'll receive a customer reference number. The reference is needed to sort funds more efficiently.
Cheers
David
