cw182
Message 11 of 59
Re: bt declined topcashback
Hi i have lodged a missing claim for my mothers account as her was not showing at all, there is no tcb reference that i can see though just a msg saying that it has been passed to BT.
Mine was showing but has just come back declined, i havent lodged a claim but will do now? sorry  you have not been able to pick up yours calls, cannt always answer the phone but can pick up emails if you want to email me? The problem seems to be the order that i raised ending in 15980 is not the same as the one BT have at their end as they had to do something.
thanks again for your help, much appreciated
DavidM
Moderator
Moderator
Message 12 of 59
Thanks for getting back @cw182.
Leave it with me and I'll chase this up for you.
Cheers
David
cw182
Message 13 of 59
thank you 🙂
i have full details if you want me to email them jut dont want to put them on here incase everyone can see.
thanks again
DavidM
Moderator
Moderator
Message 14 of 59
Hi @cw182,
Thanks for posting. Sorry I couldn't reach you today. Can you email over the amount the cashback was for and also your cashback username using the link in my profile. Let me know when you send the details over and I'll pick it up for you.
Cheers
David
cw182
Message 15 of 59
Thanks for trying to contact me, sorry you havent managed to speak to me. I have emailed over the details requested the same way i did previously. Anything else pls let me know. Thanks again for your help:)
DavidM
Moderator
Moderator
Message 16 of 59
Thanks for sending over the details @cw182.
I'm dealing with your mums account and I've raised a case to the cash back team to have this looked into. I can see you've been sent an email from your case handler on your own account so can you reply to that email. If you get stuck let me know.
Cheers
David
cw182
Message 17 of 59
When you say a case handler do you mean a BT case handler steven? if so he said he cant help with the TCB
thanks
DavidM
Moderator
Moderator
Message 18 of 59
If that's for your acount I'll jump in @cw182. Is that ok with you?
Cheers
David
cw182
Message 19 of 59
yes you can deal with the topcashback. having lots of issues with orders not going through, then going through 3 times, duplicate payments taken from my card, refunded incorrectlty my bank account, instead of my card.......dont want to bore you with the rest just grateful you can help with the tcb:)
DavidM
Moderator
Moderator
Message 20 of 59
Hi @cw182,
I tried calling today, sorry I missed you. Has your Mum received the cashback? I've raised a case for your own account and will chae this up for you as well.
Cheers
David
