Message 31 of 35
Re: bt infinity 2 first few days
i am using a 4yr old laptop to connect to hh5 , this was never a problem with my previous 8 meg  connection and i was always between 6-8 meg so not sure if its just the recent upgrade to infinity 2 , i would have thought i would have seen better speeds in top range
Message 32 of 35
The wireless kit in the laptop is most likely the limiting factor.
As I've said though, unless you're a very heavy downloader, you won't see any difference in performance from 15 to 150meg for day to day browsing/emails/gaming/streaming HD content.
Message 33 of 35
Of course it wouldn't have been a problem on your 8meg connection as the connection of yout internet was nowhere near the limits of your wifi connectivity. However the opposite is now the case given your internet connection speed.
Message 34 of 35
just want to say thanks to all who offered advice
i bought a devolo wifi stick ac and am now on the 5ghz wireless with
download 75.08
upload     11.90
ping        42.38
happy with that now
Message 35 of 35
Smiley Happy
