Message 11 of 35
Re: bt infinity 2 first few days
i have done this straight into test socket with the new filter supplied with homehub 5
1. Product name:BT Home Hub
2. Serial number:+068543+NQ61204842
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 02/06/16
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:08:43
6. Data rate:19999 / 79995
7. Maximum data rate:28038 / 86861
8. Noise margin:15.6 / 8.4
9. Line attenuation:21.4 / 18.2
10. Signal attenuation:21.5 / 18.2
11. Data sent/received:432.8 MB / 1.8 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:BTHub5-QS7S
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-QS7S_5ghz
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:90:72:82:97:1c:c2
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Message 12 of 35
your connection speed has now improved to its maximum possible this is showing a problem with your internal wiring (extensions ) reducing the connection speed
Message 13 of 35
ok john thank you for that will try and see what problem might be
Message 14 of 35
This diagram may help.
Message 15 of 35
Was that a wired or wireless test?
Message 16 of 35
I didn't get an answer to that question when I asked.
Message 17 of 35
Apologies it was on a wirless connection
Message 18 of 35
Guessed so, unfortunately wireless speed can't be guaranteed, there are too many variables to interfere with the signal.
Message 19 of 35
What is the noise margin and is this a problem
Message 20 of 35
the noise margin is not a cause of your problem and you have a maximum possible connection speed you are very close to your fibre cabinet
