ktnch
Message 1 of 3
bt infinity slow problems
Bit of a strnage one, every day speed drops to around 1.5-3.5mb and everything takes so long to load off the net, this os both wired and wireless, after restarting the home hub 5 speed gets back to around 30-50mb, this has only happened over the last week or so but getting really anoying any ideas ?
2 REPLIES 2
ktnch
Message 2 of 3
Re: bt infinity slow problems
before a reset
after a reset
imjolly
Message 3 of 3
are you using the test socket with a new filter or do you have a SSFP?
can you go to hub manager then troubleshooting then helpdesk and post 1-12
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
try quiet line test  dial 17070 option 2  should be quiet no hiss/crackle and best with corded phone
run btspeedtester and when first test completes then run diagnostic test and post results  must be done wired
