Message 1 of 15
bt infinity speed issue for 3 weeks
hi  we had bt infity up to 76 mb,on april 9th we had 70mb.. for the last 4 weeks we are only geting 44mb download
service status is ok.
quite line test is ok.
router info is.
8.
Noise Margin:
20.2 / 9.4
9.
Line Attenuation:
0.0 / 18.7
i run the bt speed test the resaults are.
  1. Best Effort Test:-provides background information.
Download Speed
44.4 Mbps
0 Mbps
45.84 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 44.4 Mbps
 For your connection, the acceptable range of speedsis 36.67 Mbps-45.84 Mbps .
 Additional Information:
 IP Profile for your line is - 45.84 Mbps
  1. Upstream Test:-provides background information.
Upload Speed
7.72 Mbps
0 Mbps
20 Mbps
Upload speed achieved during the test was - 7.72Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
any help would be great many thanks
14 REPLIES 14
Recognised Expert
Message 2 of 15
Re: bt infinity speed issue for 3 weeks
Lokk at this page and post your stats. Remeber to take your phone number out:
https://www.btwholesale.com/includes/adsl/main.html
If my post has been useful, please click on the Ratings star on the left-hand side of the post.
If I have answered your question correctly please let me know by clicking on ’Mark as Accepted Solution' Thanks
Message 3 of 15
many thanks
Recognised Expert
Message 4 of 15
Try a quite line test
Dial 17070. You will reach BT's line test facility.(Try and use the test socket for the best results)
Choose option 2 from the menu presented - "Quiet Line Test".
There should be no noise. If their is you should report to BT
Message 5 of 15
 quite line test, is good no noise
thanks
Recognised Expert
Message 6 of 15
Can you post stats from the helpdesk in the hub options
Message 7 of 15
thanks is this all you need
Recognised Expert
Message 8 of 15
 On the speed test did you do further diagnostics?
Message 9 of 15
was this a self install or engineer?  if self install can you connect to test socket
Message 10 of 15
yes i run the diagnostics and i posted the resaults on here on my first post. i noticed we are getting the speed the the ip profile is set at
thanks
