liamscor
Message 1 of 18
bt infinity sync speed changing
Hi to everyone
About 2 months ago I upgraded to bt infinity 1 with and estimate speed of 24mbs, I was for a few weeks getting 15mbs then recently my speed suddenly shot up to 18.54mbs after I restarted my hub. But then my upload was really slow at 800kbs, and then my download speed dropped back down the 15mbs a second.
I have the HHB 5 and it seems to keep resyncing, can anyone help will the recent speed increase and drop and slow upload. Also my upload when I was getting 15mbs was at about 2mbs then it went to 800kbs before my download speed increased to 18mbs.
Thankyou
17 REPLIES 17
StephanieG
Community Manager - Retired
Message 2 of 18
Re: bt infinity sync speed changing
Hi @liamscor,
Welcome to the forum!
Are you still having problems with this? You mentioned your Hub keeps resyncing so can I just check, do you mean that you're losing connection altogether, or that your wireless connection is dropping? (I’m sorry if this seems like an obvious question, I just don’t want to make an assumption either way).
Please can you run a test here and post back the outcome?
Thanks,
Stephanie
liamscor
Message 3 of 18
Hi stephanieG
Thankyou very much for your reply. I did a bt speedtest diagnostictics the results are below, also i am using a wired connection.
liamscor
Message 4 of 18
Here is some more information on my bthomehub5
pippincp
Sage
Message 5 of 18
Run THIS test and after the first run click on "Further Diagnostics". Post the result of the second test.
liamscor
Message 6 of 18
Here are the test results you asked for. Also just so you know I have bt powerline adapters do you think these could be causing interference thanksUntitled3.png
legitimise_sailing
Distinguished Expert
Message 7 of 18
What estimate does the dsl checker give for your phone number?
www.dslchecker.bt.com
To say thanks for a helpful answer, please click the white star
liamscor
Message 8 of 18
Hi thankyou for your response
This is what is says.
*edited for security*
john46
Message 9 of 18
can you please edit out your phone number as this is a public forum
legitimise_sailing
Message 10 of 18
Ok, looks like you're at the bottom end of the Range B estimate and that's probably due to the HH5 resyncing a lot. The performance test you posted earlier seemed to think you should be getting at least 20Mbps.
The powerline adapters could be causing some interference, but I'd say the problem is because of the HH5 which there are numerous reports of on here.
