redstar
Message 21 of 49
Re: bt poking my connection
Hi home hub 3 plus eci modem
Bullitt
Distinguished Expert
Message 22 of 49
unlucky
its easy on a huawei echolife hg612 3b modem
RogerB
Guru
Message 23 of 49
@Bullitt wrote:
its normal and it can be blocked
So ...... why would you want to block it?
Bullitt
Message 24 of 49
have you any intention of getting infinity?
RogerB
Guru
Message 25 of 49
What does that have to do with it ...?
Bullitt
Message 26 of 49
because unless you are i cant see any value in answering your question
RogerB
Guru
Message 27 of 49
ok .... answer this.
The whole idea of having an internet connection is to ..... well, browse the net, is it not?
Bullitt
Message 28 of 49
is it? what about email?
RogerB
Guru
Message 29 of 49
yes .... good!
email as well 🙂
Do we agree?
MBR123
Expert
Message 30 of 49
Just a pointer, Port 161 is used by BT to help upgrade and perform the HH3, it is also for BT to help maintain a good online gaming sytem, pings etc..,  if you block this port you will stop BT from performing upgardes to your modem. Its not a good idea. 😞 Just a friendly tip!.
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
