Message 11 of 30
Re: bt speed halved
Message 12 of 30
Re: bt speed halved
Downstream 11,607 Kbps
Upstream 1,175 Kbps
Message 13 of 30
Re: bt speed halved
what option are you on
Message 14 of 30
Re: bt speed halved
Unlimited Broadband
Message 15 of 30
Re: bt speed halved
with a connection like that you should be well above 2mb have you checked your usage as even on unlimited you have a 300gb limit and you may have been capped for exceeding it
Message 16 of 30
Re: bt speed halved
i dont d/l and have little usage only for xbox or ps3 and daily web browse
like i said over the past 6 weeks im geting more disconections and speed was fine then ive tested it trhis weekend  and its down to 2.5 from 5.8
Message 17 of 30
Re: bt speed halved
when you looked up the connection stas did you see any information on any crc errors, hec errors,fec errors, and error seconds,
the only other test is the noise test dial 17070 on your phone and option 2 if you hear any hissing or crackling then you have noise on your line which is a job for bt and not much you can do about it other than buying a bt accelerator plate from here http://www.shop.bt.com/products/bt-iplate---bt-broadband-accelerator-58LT.html
Message 18 of 30
Re: bt speed halved
ok found this
xDSL linestate up (downstream: 11622 kbit/s, upstream: 1173 kbit/s; output Power Down: 20.0 dBm, Up: 12.0 dBm; line Attenuation Down: 28.0 dB, Up: 14.0 dB; snr Margin Down: 6.5 dB, Up: 6.5 dB
Message 19 of 30
Re: bt speed halved
they seem fine did you do the quiet test
Message 20 of 30
Re: bt speed halved
No  hissing or crackling
the only other problem is that sometimes on the two home phones we always get a dialiing tone but some times when you press the numbers on the phone it dosent dial it says on the dial tone
so i changed the filters and unpluged phones tried diffrent phones and this still happens
ive unpluged all phones and still get the low speed
there is NO cap on the bb i have asked
