spaceman
Message 1 of 11
bt sport problem
I have a hub3 on bt copper wire.The picture on bt sport keeps breaking up,but occasionly it's perfect.My connection speed is 12.4mb,with download at 10.8 and 0.98 upload.I can get around the internet ok.Anyone having the same problem.
10 REPLIES 10
blownfuse
Message 2 of 11
Re: bt sport problem
I know the feeling. I just get '' loading 100%. Have yet to see BT Sport. Going back to Sky when my contracts up. Sorry I have nothing to help you as I have gone through all channels open to me with BT and have got no where
Nickaminsky
Message 3 of 11
Hi.
Similar connection speed here. I am finding BT sport pretty good on Android 4.3 (nexus 10), no break up at all.
On my windows 7 64-bit Nettop, BT sport breaks up for the first 10 mins or so and then is pretty stable, albeit it seems like slight frame skipping but no breakup. Its a sharp picture and watchable.
I put this down to Silverlight trying establish a high steady bit rate or something. Its rate adaptive I think, or is this what Silverlight "smooth streaming" is?
It seems to try 4 or 5 times to get a higher bit rate where I get stuttering and then it stablises.
I'm running this on a Revo R3700 which is only an Atom CPU. I think Silverlight 5 is supposed to support GPU acceleration. So I'm not sure whether that has anything to do with it.
The above is with IE version 10. I also tried it on Chrome and it was awful, really low bit rate and unwatchable.
spaceman
Message 4 of 11
Thanks nickaminsky,I have a 5year old Toshiba,maybe I need to get a new one.
spaceman
Message 5 of 11
Thanks blownfuse,I have tried phoning and emailing bt to no avail.how do they keep customers?
blownfuse
Message 6 of 11
Spaceman,  Try the following because I gave up on BT and went at it myself and after practically removing every programme and reinstalling the back ups I seem to have found a simple solution.
1. First uninstalled Microsoft IE.
2. Downloaded and Applied Goggle Chrome as the search engine
And guess what it works. I'm not sure why but when installing Chrome it applied a Java and Silverlight 5 update which I knew I already had on Microsoft IE but didn't work. Anyway it all works now.  Good luck
Nickaminsky
Message 7 of 11
I had loads of problems trying to watch BT Sport on my PC last night (6030 errors and VC019), whilst viewing on my Android tablet was perfectly fine.
I tried re-installing Silverlight, it didnt really make much difference.
Eventually it started to work. I get the impression from other threads and users that theres loads of problems with Silverlight and BT Sport.
bzcbzc
Message 8 of 11
I would like to ask 'Blownfuse' what version of Windows are you running under when Google Chrome enables you to watch BT Sport online.
spaceman
Message 9 of 11
blownfuse,My laptop is a 4year old Toshiba L450 which works perfectly on the internet.I am using Chrome myself,and I have tried IE as well and it worked great for 3mins and froze up-I had to do a forced close to get out of it.I have silverlight 5.I am going to check my Java.Thanks for your help.
blownfuse
Message 10 of 11
BczBcz,
Microsoft 7 on the house laptop and 8 on the kids. Seems to work well on all. Just Guessing but there must be some form of software problem with Microsoft IE and SilverLight and BT Sport.
Goggle Chrome works well. No bufferring, no pausing. Just all smooth.
Regards
Blownfuse
