MotBarber
Message 11 of 25
Re: btinternet email doesn't work with MS Outlook 2013
gg30340,
Thank you.  It was user error.  I re-tried your suggestions, and now I am happily up and running again, and emails are arriving in Outlook without delay.
I cannot tell you how grateful I am, that you read, and bothered to send me such a considered response.  Thank you very much indeed.
BT could do with someone like you on their help pages, let alone Microsoft (and You Tube for that matter).
Thank you.
MotBarber
Message 12 of 25
Thank you Licqourice, you are right, gg was right - see my last post.  Very grateful for all your help and advice.
gg30340
Message 13 of 25
Glad it's working for you. It is easy to miss something.
bmcl26
Message 14 of 25
All versions pf Outlook that I have used 97, 2003 & 2010 have all worked seemlesly with my BT Email.  Never had an issue..
MotBarber
Message 15 of 25
wait til you try 2013, it's a laugh a minute
bmcl26
Message 16 of 25
Outlook 2013 works fine for me.
Steve_Ballantyne
Message 17 of 25
I know this is an old thread, but i'm having exactly same issues with BT. Impossible to get a sensible answer from them.
I agree with original Contributor MotBarber - FACE UP AND ADMIT YOU HAVE A PROBLEM !!
Andy_N
Distinguished Guru
Message 18 of 25
Hi. Welcome to the forums.
Has this issue just started for you ?
Mine works fine with Outlook 13, first in Windows 7 and now in Windows 10.
@What sort of settings do you have ? Sometimes setting the login username to be just the "stub", i.e. the bit before the @btinternet.com only can work.
Andy_Chappell
Message 19 of 25
I experienced problems with downloading emails and they seemed to be related to standard buttons that did not work on the menu bar.  I solved it by using a button on the Quick Access toolbar at the top of the screen.
Andy Chappell
Hwalker11
Message 20 of 25
Me too!
