lukalily
Message 1 of 19
caller display
I have a logik (L06COMB10) telephone, which has the caller display with it. I rang BT and ordered the privacy setting with caller display which bt say is now operational on my line. When anyone rings me I just get 'calling' comes up with no number displayed. Any thoughts on what I can do? I have got in touch with bt who told me what numbers to dial to set it up, and I got a message saying it was working on my phone but it obviously is not.
18 REPLIES 18
Distinguished Guru
Message 2 of 19
Re: caller display
Hi and welcome
Try dialling *#234# from your phone, you will get an announcement saying if caller display is active on your account or not.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
lukalily
Message 3 of 19
Re: caller display
Thank you, I have tried that and got a message saying callers identities will be displayed but unfortunately they are still not being displayed.
Carol
Patty-L
Recognised Expert
Message 4 of 19
Re: caller display
Might be an obvious answer and perhaps you have tried it, do you have another caller display phone or could you borrow one to see if it worked on that.
Distinguished Guru
Message 5 of 19
Re: caller display
Hi, I would suggest unplugging all ADSL filters, and any equipment you have plugged into phone sockets. I have had experience where certain routers and filters can mask caller display.
lukalily
Message 6 of 19
Re: caller display
Do I not need to have these filters attached because of my broadband connection? Sorry not very technical minded.
Distinguished Guru
Message 7 of 19
Re: caller display
just try the phone plugged in on its own with no filter and bb unplugged just to prove the fault
bfg
Message 8 of 19
Re: caller display
HI LUkalily,
You do need the Microfilters plugged in to 'filter out' the broadband 'noise/signal' and allow you to have a broadband on at the same time as receiving and making calls.
But, Devon dave is suggesting you try without the filters, just to see if they are stopping the caller display.
The caller display is actually 'tones' before you answer the call and the filters can filter out more than they should and stop the caller diaplay working (your phone doesnt hear the 'tones' and acts like you dont have caller display on the line).
hope that helps Smiley Wink
lukalily
Message 9 of 19
Re: caller display
Have tried removing the filters, still no joy. Perhaps the fault is with the phone.
djh22
Recognised Expert
Message 10 of 19
Re: caller display
Is the phone set to TB ?
Del.
