rustygoat
Message 1 of 7
can't connect to BT ASDL using Asus router & Draytek 120 modem
hi folks
trying to setup a Asus rt-ac66u router with draytek vigor 120 modem (instead of the old BT HH4)
the draytek 120 is set to PPPoE with its default settings
all the lights are on except the internet light ( power, ACT, Lan, DSL all on)
below shows the asus wan setup
the asus shows its trying to connect, but no joy
i'm assuming i have a/some settings wrong
can anyone help
6 REPLIES 6
licquorice
Message 2 of 7
Re: can't connect to BT ASDL using Asus router & Draytek 120 modem
2 things.
ADSL is PPPoA VPI/VCI 0/38rather than PPPoE
You are missing the .com on the PPP username it is bthomehub@btbroadband.com
rustygoat
Message 3 of 7
thanks i'll have a go at those things
DavidM
Moderator
Moderator
Message 4 of 7
Hi @rustygoat,
Have you tried @licquorice advice? Has it solved the problem? Can you post back and let me know how you're getting on.
Cheers
David
rustygoat
Message 5 of 7
not tried it yet, askids doing uni work, so need to have internet running will try later
rustygoat
Message 6 of 7
changed user to bthomehub@btboradband.com as suggested works now, kept it as PPPoe works ok
don't say its changed the speed etc, but i now have a VPN service on my network
as said i am on ASDL line 20mg, with a Draytek Vigor 120 modem and a Asus router RT-ac66u with merlin software
DavidM
Moderator
Moderator
Message 7 of 7
Sounds like you have it sorted @rustygoat. Thanks for letting us now.
Cheers
David
