benny
Message 1 of 2
can you use BT Connection Manager with the hub?
hi - probably a stupid query this but am new to BT home BB with the hub, previously used a mobile BB dongle which had a little box on screen that kept you constantly up to date with MB used, time used etc.
looked for something similar with BT and see its the BT Connection Manager:
http://btbusiness.custhelp.com/app/answers/detail/a_id/11367/c/593,2296,2298
but i cannot figiure out how to load it up. here its talks about inserting the USB modem into one of your laptop's USB connections?
http://bt.custhelp.com/app/answers/detail/a_id/12856/c/346,2732,2737/related/1
but i wasnt given a USB modem?
is this BTCM only for mobile BB? (like a dongle)
1 REPLY 1
IceZaroth
Message 2 of 2
Re: can you use BT Connection Manager with the hub?
First off Hiya and sorry for the delay of a responce ...
Might i point you to this url page you can download and install this broadband monitor
http://www.thinkbroadband.com/tbbmeter.html
To which you can setup daily,weekly or monthly alarms and it'll tell you when you've reached the limit you've set, it also can monitor any and all network traffic movements its a handy little free utility.
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution’
Best Wishes
IceZaroth
BT Community Helper
