spokegg
Newbie
Message 1 of 3
cancelling call-barring
I have set up call barring but need to remove it. I am being told by the instruction PDF to tap in hash34code*pinhash. I am not aware of having a pin number, how do I find this out?
Regards
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: cancelling call-barring
Try 1234, if not, then you will have to ask BT to send it in the post. Usually you would have been informed of it when you ordered the service.
From BT Website
"If you forget your call barring PIN you will need to contact BT for a reset. In some of our exchanges the Call Barring service locks after 3 failed attempts. If you suspect that this is the case then you will need to contact us on 0800 800 151"
hippey
Expert
Message 3 of 3
Good luck getting it! I got locked out a few weeks ago on one of my lines and no one could find the PIN!
