Savagerapture
Message 1 of 15
cant connect to bt open zone
normaly i have no problems conecting to the bt hot spot on my laptop at home. but today i have been trying for hours. my laptop keeps saying accsess is limited and as i try to load the web page to log in to my account to accsess my net, it wont take me to the page as it normaly dose. i have restarted my laptop countless times. disconected then re conected to the net and tryed on my flatmates laptop aswell. i paid for 5 days worth of net accsess on wednsday morning and now cannot accsess the page to log in. anyone ells had this problem??
14 REPLIES 14
jac_95
Guru
Guru
Message 2 of 15
Re: cant connect to bt open zone
Hi Savagerapture,
Try connecting to the BTWifi or BTWifi-With-Fon hotspot (BTOpenzone/BTFon).
Once your device is connected to the hotspot, open your browser.
If the BTWifi Login Landing page does not load, try going to https://www.btopenzone.com:8443/ while connected to the BTWifi hotspot.
Hope that works,
Cheers
Savagerapture
Message 3 of 15
i have been trying by conecting ti BTWiFi then trying to load the log in page. this dosent seem to be working
Savagerapture
Message 4 of 15
when i conect to ITHER of those it says they are limited there for refuses to load the log in page
jac_95
Guru
Guru
Message 5 of 15
Have you tried "Forgetting" the network on your device?
Have you tried trying one restart of the Home Hub?
Cheers
Savagerapture
Message 6 of 15
i dont have a home hub. this is bt openzone pay for days of usage at a time
Savagerapture
Message 7 of 15
have now tryed forgetting network, and now still not working
Devon_Dave
Distinguished Guru
Message 8 of 15
If you are trying to connect to some elses BTwifi hot spot they may have an issue with their hub or access to the internet.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Savagerapture
Message 9 of 15
i am trying to conect to the BT HOT SPOT openzone. it comes up its limited! witch has never happend before. i have dun the things listed above. it is not someone ellses net. its net i have paid for
Savagerapture
Message 10 of 15
if it helps, it comes up the ! on the BTWiFI and BTWiFI-with-FON before i conect to it. any advice?
