Message 1 of 3
change the number
Hi
My sim card from BT has just reached my address, I just don't like the number allocated, can we change this number? or can i move my number from a different operator to bt? Will this affect my contract? thanks.
2 REPLIES 2
Message 2 of 3
Re: change the number
You can keep your old number and port it to BT, simply text the word PAC to 65075, then follow the instructions supplied with the sim welcome pack to use it, your old mobile number will cease with the other operator, It won't affect your BT contract, it might if you're within a minimum term with your old provider, the text message will inform you if any apply.
You can request a renumber but you might be charged, not sure how much though for BT mobile, for a landline it's £26
Message 3 of 3
You can renumber your BT Mobile for free, including subsequent renumbers.
