Message 1 of 4
comtrend
Please could someone tell me how do i pair a third comtrend adapter to work on my net work ,thanking thee veryly much ..i rekon i have to plug it in at side of main sender thats pluged into router and press config button but do i press them both ..?
3 REPLIES 3
Message 2 of 4
Re: comtrend
just plug it in and select either of the other two and just pair as you did initially.  it will then the 3 paired instead of 2
Distinguished Guru
Message 3 of 4
Re: comtrend
Except that most of them come pre-paired, so you just take them out of the box and start using them.
You need to find the manual for the adaptors you've got (if one isn't in the box, try Googling for it).  It will  most likely involve plugging two in next to each other and pressing the bittons for the right amount of time.
Message 4 of 4
Re: comtrend
thanks ,cheers,ta very much ......
