Hi, having a couple of problems lately, its a bit of a 2 part problem and im hoping somone can help.
1. I received an email tody telling me that ive reached 7GB usage of the 10GB, even though i was only set up on the 30th of March, thats just over a week. there is no way i could of reached this in just over a week, not with what i use the internet for.
In fact i was so suprised that i had to check the hub settings, mine reads; Data Transmitted/Received (GB):0.3 / 4.2 Does this seem right? im not quite sure
2. when i checked in mybt, the usage says this message "theres no recent usage because you do not have any products or services linked to this account."
what does this mean? its the same when i check the bill, theres no charge, no usage. Maybe its an error, i cant be sure.
Can anyone shed some light on this? im giving them a ring tommorow either way.
I would use the online chat better than phoning. the usage shown in your hub is only of use if the connection time shows more than 8 days otherwise it resets to zero if hub resets
It certainly looks as though you need to contact BT. Here's the link: Live Chat.
Further to what potters [shorthand ] has said, save the transcript in case it gets a bit tricky later.
Doesnt look right to me though I have to say
i used the online chat thing. it turns out that couldnt access my account because they had the wrong account number! go figure.
as far as the usage goes, which i had a very long chat about, their usage monitor is 100% accurate...apparently.
Does this make the hubs data completely useless????
they gave me a complete breakdown of how much i was using and on which days. But, this feature, i could not use. because ive not been able to see the usage monitor yet, i dont know, apparentely it just gives you an overall usage for the day, is this true?
its looks like theres no real way around this, that is what ive used, i have to take their word for it, which in itself isnt 100% accurate!
i still have to wait 48hrs to see if everythings sorted out,
thanks for your help guys.
Coincidentally, I posted this today: http://community.bt.com/t5/Other-BB-Queries/Connection-Data-on-Home-Hub-Incorrect/td-p/463603.
I don't have a problem with it as I am reasonably sure that the Usage Monitor is a fair statement. But it does illustrate a significant discrepancy between the monitor and the hub. If I had doubts like the OP, I would not be a happy bunny.
I wouldn't bother trying to ring BT.
It seems that one is put through to a curry takeaway somewhere in the world where the spoken English is barely understandable.
I have received 2 emails from BT about exceeding my broadband usage I have 40GB.
My normal usage is apparrently 17gb per month, I have exceeded in 2 days the remaining usage of 23 gb.I am not doing anthing different from normal.
I have notified the takeaway that they have tested & told me that there is a problem.
Bt have sent 2 engineers out, one replaced the modem, the second tested and replaced the hub as faulty.
They have also said there is a problem on the line. Thats it, no answer given as to what happens next other than my bill is exceedingly high.
Would not bother trying to get in touch with BT.
I am looking at Virgin who are really touting business.
As for BT, they want £300.00 cancellation of service, they can swing, If they take me to court all the better I will make sure that the press hear how they are hounding a pensioner which I am. I would rather go to jail and live better than continue with the useless and disgraceful service that I get from BT.
CJS
