clairerover
Newbie
Message 1 of 2
connecting more than 6 wireless devices to homehub 3
how can i connect more than 6 wireless devices to homehub 3? my current cable provider allows me to have 9 wireless devices connected at the same time
is there a way to connect a wireless router to homehub 3 or do i need to invest in a modem router from another make that allows me the extra connectivity?
1 REPLY 1
Message 2 of 2
Re: connecting more than 6 wireless devices to homehub 3
Hi you can have as many wireless devices as you wish the same applies to wired connection's if you use an Ethernet switch all you need to do is enter the wireless security code into each wireless device
