Newbie
Message 1 of 8
connecting my broadband cuts out my telephone line
I have set up my new Bt Home Hub 3 for BT broadband and BT sport. I also have a BT telepone line that previously worked perfectly.  For 2 days broadband, wireless and telephone worked perfectly, then we lost our telephone connection.
After following the help information of disconnecting and reconnecting anything pluged into a phone connection I realised that every time I connected to the boadband the telephone line cut out.
I have reportrd this as a fault and been on the online chat help line, without success.  Is there something I may have done incorrectly in the setup?  We have an all wireless computer, printer mouse and keyboard.
7 REPLIES 7
Message 2 of 8
Re: connecting my broadband cuts out my telephone line
Can you get dial-tone on your phone when the HH3 is unplugged?
If you plug the HH3 in, and call your phone number from a mobile, do you get busy tone?
If you do, then it sounds like the HH3 is faulty, and looping the line.
Newbie
Message 3 of 8
1. The number dials but does not connect when HH3 is connected.  When I disconnect HH3 phone works fine immediately
2. With HH3 connected if I call my landline from my mobile I get BT message"the person you are calling is on the phone".
Message 4 of 8
sorry but you are using a filter?
Message 5 of 8
Then your home hub 3 is short circuiting the line, and is faulty. This can happen if the internal lightning protection device goes faulty, usually after a storm.
If you have access to another home hub, you could try that. If not, then Ring the BB helpdesk, and ask them for a replacement home hub.
Edit:- It could be a faulty filter, as IMJ has said, so its worth trying another one.
Newbie
Message 6 of 8
I have tried all the suggested routes to solve my problem.  Old hub wouldn't connect to Internet.  Taking out filters made no difference.
What next?  Is the a line fault or a broad band fault.  Why was everything working perfectly until I changed to this new BT BB package?
Message 7 of 8
as Keith has posted you have a faulty hub and you need a replacement they do go faulty sometimes you need to contact the Broadband help line 08001114567 and ask them to send you a new hub
Newbie
Message 8 of 8
Thanks for your help.  I have spent 5 days try to sort this problem and as you and Keith have said I think the HH3 is faulty.
BT are sending me a new one so hopefully all will work as it should.
Thanks again everyone for your support.
