laughing_gravy
Message 1 of 8
connecting ps3 to bt wifi
I am having trouble connecting the ps3 to bt wifi. I have tried using automatic ip and fixed ip (using the details for default gateway etc that I got from ipconfig on my pc). The ps3 seems to obtain an ip address, but when I go to the browser, I just get a white page, so cannot see the login forms!
7 REPLIES 7
gg30340
Message 2 of 8
Re: connecting ps3 to bt wifi
laughing_gravy
Message 3 of 8
I saw that thread earlier and have already tried the advice but still no luck. any other suggestions?
gg30340
Message 4 of 8
I don't have a PS3 so can not give first hand advice but I would try a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds. This can sometimes sort out any configuration problems. Once it restarts follow the suggested method to connect in the previous link I posted.
Devon_Dave
Distinguished Guru
Message 5 of 8
Hi. Are you trying to connect to your own wifi or a wifi hot spot?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
laughing_gravy
Message 6 of 8
a hot spot, (because BT have still not activated my broadband after FOUR WEEKS!)
gg30340
Message 7 of 8
If your broadband is not activated, your primary email address and password will also not be activated and you need that to log onto BTWifi unless BT have given you a temporary one.
laughing_gravy
Message 8 of 8
I am using the temporary login, this is working fine on my pc
