Message 1 of 11
connection issues
Good afternoon, if someone in the know could take a look at my problems they'd be most appreciated.  I moved properties and my bt/internet came online on Wednesday as planned.  In the evening my connection was dropping out all over the place, but your supposed to expect issues for up to 24 hours i believe so left it alone.
Anyway I work over the internet but only use ssh so not likely to spot a lot of issues as its real light use...so who knows when it started, but Friday afternoon it started cycling through disconnect, then reconnect, then about 30 seconds before repeat.
I've been thru the obvious reconnecting all the cables, swapping out microfilters, resetting the router and still the problem persisted.  I rang up via the 0800 number the hub tells you to call.  I went without Internet for about 3 weeks earlier in the year whilst these support people gave me the run around and didn't really listen to me...but i rang anyway.  The guy was seemingly helpful and proceeded to get me to remove the plate and plug into the other socket and then run some tests.  Nothing noticeable happened on my end, he proceeded to take my mobile number...called me on it to let me know to keep off the line whilst he tested, and that he'd call back when done.  He didn't call back, but about an hour later it stayed connected which allowed me to continue to work.  It stayed connected from then...
Although the 'broadband' has been on, general Internet use has been awful, i can't watch youtube, iplayer and such at all without only a few seconds of use before it cutting out.  Was getting 1500ms ish ping to places like google and such.
I bought 1.25gb game on the xbox earlier which its been 'downloading' > 8 hours and got to about 60%...despite constant broadband connection.
I've recently reset the router (homehub 2) and its gone back to the cycling between dc'ing, reconnecting.
I really don't want to go thru the weeks of pain and hassle i went thru before and seem to remember this forum actually resolve it all.  Last time i had to spend weeks working in public places to leech/use public wifi.
Looking at these forums for suggestions i've rang the 17070 option 2 number and only heard quiet ( or possibly a slight hum...but i guess that is just audio 'nothing' ).
In case any BT types are about my landline number is ***removed****
i never have a landline plugged into it so is no worry for randoms calling it 🙂
Anyway if some lovely person can offer some advice i'd be eternally grateful
regards,
James
I took a copy/paste of my routers stats yesterday for use, and here they are...
ADSL line status
Connection information
Line state Connected
Connection time 0 days, 0:08:32
Downstream 9,959 Kbps
Upstream 968 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.5
Latency type Interleaved
Noise margin (Down/Up) 5.8 dB / 5.7 dB
Line attenuation (Down/Up) 31.0 dB / 16.4 dB
Output power (Down/Up) 20.7 dBm / 12.4 dBm
Loss of Framing (Local) 4
Loss of Signal (Local) 2
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 2
CRC Errors (Down/Up) 4797 / N/A
HEC Errors (Down/Up) N/A / 1098352
Error Seconds (Local) 2
15:08:43 18 May LOGIN User admin logged in on [HTTP] (from 192.168.1.67)
15:08:42 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:08:14 18 May LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
15:07:22 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
15:07:19 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
15:07:19 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:07:17 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:06:55 18 May CONFIGURATION saved by TR69
15:06:29 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] 200 OK - SIP message received
15:06:24 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:06:24 18 May FIREWALL event (1 of 5): deleted rules
15:06:23 18 May PPP link up (Internet) [86.186.156.73]
15:06:23 18 May PPP CHAP Chap receive success : authentication ok
15:06:23 18 May PPP CHAP Receive challenge (rhost = bras-red4.mqd)
15:06:17 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:06:07 18 May PPP link down (Internet) [86.162.65.4]
15:05:45 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:05:44 18 May FIREWALL event (1 of 3): modified rules
15:05:44 18 May FIREWALL event (1 of 5): created rules
15:05:44 18 May xDSL linestate up (ITU-T G.992.5; downstream: 9959 kbit/s, upstream: 968 kbit/s; output Power Down: 20.8 dBm, Up: 12.4 dBm; line Attenuation Down: 31.0 dB, Up: 16.4 dB; snr Margin Down: 5.0 dB, Up: 5.9 dB)
15:05:17 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
15:05:14 18 May xDSL linestate down
15:05:08 18 May FIREWALL event (1 of 4): deleted rules
15:05:08 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:05:07 18 May PPP link up (Internet) [86.162.65.4]
15:05:07 18 May PPP CHAP Chap receive success : authentication ok
15:05:07 18 May PPP CHAP Receive challenge (rhost = bras-red4.mqd)
15:04:50 18 May PPP link down (Internet) [81.159.40.149]
15:04:30 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:04:29 18 May FIREWALL event (1 of 2): modified rules
15:04:29 18 May FIREWALL event (1 of 3): created rules
15:04:29 18 May xDSL linestate up (ITU-T G.992.5; downstream: 10052 kbit/s, upstream: 976 kbit/s; output Power Down: 20.8 dBm, Up: 12.3 dBm; line Attenuation Down: 31.0 dB, Up: 16.4 dB; snr Margin Down: 5.0 dB, Up: 5.9 dB)
15:04:13 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:04:08 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
15:04:07 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:04:05 18 May CONFIGURATION saved by TR69
15:03:59 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:03:59 18 May FIREWALL event (1 of 2): deleted rules
15:03:59 18 May xDSL linestate down
15:03:59 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:03:37 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
15:03:36 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] 200 OK - SIP message received
15:03:31 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:03:30 18 May PPP link up (Internet) [81.159.40.149]
15:03:30 18 May PPP CHAP Chap receive success : authentication ok
15:03:30 18 May PPP CHAP Receive challenge (rhost = bras-red4.mqd)
15:03:27 18 May FIREWALL event (1 of 1): modified rules
15:03:27 18 May FIREWALL event (1 of 1): created rules
15:03:27 18 May xDSL linestate up (ITU-T G.992.5; downstream: 9911 kbit/s, upstream: 952 kbit/s; output Power Down: 20.6 dBm, Up: 12.3 dBm; line Attenuation Down: 31.0 dB, Up: 16.4 dB; snr Margin Down: 5.0 dB, Up: 5.9 dB)
15:02:57 18 May FIREWALL event (1 of 1): deleted rules
15:02:57 18 May xDSL linestate down
15:02:32 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:02:25 18 May FIREWALL event (1 of 2): modified rules
15:02:25 18 May FIREWALL event (1 of 4): created rules
15:02:25 18 May xDSL linestate up (ITU-T G.992.5; downstream: 9903 kbit/s, upstream: 968 kbit/s; output Power Down: 20.8 dBm, Up: 12.1 dBm; line Attenuation Down: 31.0 dB, Up: 16.4 dB; snr Margin Down: 5.0 dB, Up: 5.9 dB)
15:02:09 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
15:02:08 18 May LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
15:01:55 18 May FIREWALL event (1 of 4): deleted rules
15:01:55 18 May xDSL linestate down
15:01:43 18 May PPP CHAP Receive challenge (rhost = bras-red4.mqd)
15:01:36 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:01:28 18 May LOGIN User Basic logged in on [HTTP] (from 192.168.1.67)
15:01:26 18 May PPP link down (Internet) [86.149.66.42]
15:01:18 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:01:09 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:01:07 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:01:06 18 May FIREWALL event (1 of 3): modified rules
15:01:06 18 May xDSL linestate up (ITU-T G.992.5; downstream: 10007 kbit/s, upstream: 936 kbit/s; output Power Down: 20.8 dBm, Up: 12.3 dBm; line Attenuation Down: 31.0 dB, Up: 16.4 dB; snr Margin Down: 5.0 dB, Up: 5.9 dB)
15:01:04 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:01:00 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:00:58 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
15:00:36 18 May FIREWALL event (1 of 1): created rules
15:00:36 18 May FIREWALL event (1 of 1): deleted rules
15:00:36 18 May xDSL linestate down
15:00:35 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
15:00:24 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:59:48 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:59:02 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:58:16 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:58:14 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:57:31 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:56:55 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:56:12 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:55:30 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:54:49 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:54:07 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:53:21 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:53:18 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:53:15 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:52:42 18 May UPnP action 'DeletePortMapping' from ip=192.168.1.67 (Success)
14:52:42 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:52:39 18 May UPnP action 'AddPortMapping' from ip=192.168.1.67 (Success)
14:48:38 18 May CONFIGURATION saved by TR69
14:48:12 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] 200 OK - SIP message received
14:48:07 18 May VOIP: [2.0A] [441604865727] [FXS DECT1 DECT2 DECT3 DECT4 DECT5] REGISTER - SIP message sent
14:48:07 18 May FIREWALL event (1 of 4): deleted rules
14:48:06 18 May PPP link up (Internet) [86.149.66.42]
14:48:06 18 May FIREWALL event (1 of 4): created rules
14:48:06 18 May PPP CHAP Chap receive success : authentication ok
14:48:06 18 May PPP CHAP Receive challenge (rhost = bras-red4.mqd)
10 REPLIES 10
Message 2 of 11
Re: connection issues
hi will you please edit out your phone number and postcode this is a public forum and is a customer to customer self help forum messages posted here DO NOT GO TO BT the only BT employees are the forum moderators
Message 3 of 11
Hi Welcome to the forums
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket  Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 4 of 11
As requested i've remove the landline and post code.
Yes, i've tried the test port...and done the 17070 test, thanks.
As i can't maintain a connection for more than 30 seconds currently i haven't been able to run the speed test. If this morning is anything to go by...its super slow. I'm using a "3 mobile broadband - pay as you go" dongle to get here, whic is what i ended up having to use last time 😞
thanks for your time 🙂
Message 5 of 11
you are currently in a 10 day line training period during which time you may get disconnections as the exchange equipment finds your fastest stable speed
Message 6 of 11
your speed is low most likely because of the disconnections try the test socket and see if it becomes more stable
Message 7 of 11
Not sure i'd count the constant disconnects as the trial/learning period.  I've been a DSL user for years, and (unfortunately) moved about a bit so semi familiar with that process.  This internet is not usable, and is having some serious issues.
Check out these stats from a tracert i did last night, its worth pointing out that is the only traffic on the hub at the time.  the 99ms to the hub itself is bizarre in itself but check out the rest.  I tried running the speedtest last night ( For first part check out this http://eternalrising.net/screenie1.png ), but when i did the reconnect with the different broadband username it went for the few hours to get a connection 😞
C:\Users\james-pa>tracert google.co.uk
Tracing route to google.co.uk [173.194.67.94]
over a maximum of 30 hops:
  1    66 ms    92 ms    99 ms  BThomehub.home [192.168.1.254]
  2    60 ms    61 ms    57 ms  217.32.141.131
  3  2686 ms  2565 ms  2652 ms  217.32.141.190
  4  2743 ms  2707 ms  2742 ms  213.120.161.122
  5  2710 ms  2885 ms  2748 ms  217.41.222.50
  6  2882 ms  2911 ms  2799 ms  217.41.222.182
  7  2986 ms  1872 ms  1284 ms  acc2-10GigE-0-2-0-5.bm.21cn-ipp.bt.net [109.159.
248.234]
  8  1283 ms  1331 ms  1374 ms  core2-te0-3-0-3.ealing.ukcore.bt.net [109.159.24
8.150]
  9  1329 ms  1276 ms  1384 ms  peer1-xe11-1-0.telehouse.ukcore.bt.net [109.159.
254.112]
 10  1347 ms  1409 ms  1360 ms  195.99.126.107
 11  1741 ms  1430 ms  1332 ms  209.85.252.186
 12  1512 ms  1533 ms  1433 ms  209.85.253.90
 13  1407 ms  1638 ms  1423 ms  66.249.95.173
 14  1811 ms  1331 ms  1431 ms  209.85.250.163
 15     *        *        *     Request timed out.
 16  1809 ms  1654 ms  1419 ms  wi-in-f94.1e100.net [173.194.67.94]
Trace complete.
Message 8 of 11
are you connected to the test socket as this will eliminate any noise problems caused by your internal wiring?
Message 9 of 11
how are you connecting to the hub wireless or ethernet cable
Message 10 of 11
as per above, yes im using test socket.  also used wired.
Have had some joy after a few calls to bt today.  something was fixed at the exchanged, and connectivity is back 😄
