Message 1 of 10
connection lost to Rapidshare.
Since mid morning the connection to Rapidshare is down.
On checking around, U.S.A. connections are good.
It appears to be only one ISP, BT.
anyone else having problems?
9 REPLIES 9
Message 2 of 10
Re: connection lost to Rapidshare.
my rapidshare connection down too from this morning
was fine last night
a non bt user tells me the site is finel
anyone know what the problem is and when it will be fixed
Message 3 of 10
yep me too... but i can't find any reason for it... come on BT sort it out
Moderator-Retired
Message 4 of 10
There are numerous threads from other users reporting similar problems, and from what I've read elsewhere this isn't a problem which is unique to BT as customers of other ISPs seem to having the same problem. We are going to run some investigations from our end and once I know more I'll report back to the forum.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Message 5 of 10
Moderator .thanks for your quick response and looking forward to hearing the results of your checks
i have a friend who isnt on bt and he is connecting fine to rapidshare this morning
it was connecting fine last night using bt
thanks again
Message 6 of 10
Connection is back up:
Upload and download speed is 1/4 of what it was.
Message 7 of 10
glad to hear our connection is now ok please post back if further problems occur
Message 8 of 10
Download speed is back to 1MB/s
upload is still slow at 13KB/s. used to be 100KB/s
Message 9 of 10
just a matter of waiting for things to get totally back to normal
Message 10 of 10
moderator
mnay thanks.problem was resolved early this afternoon.
very grateful for the speedy resolution to this problem
