Newbie
Message 1 of 7
connection lost
hi
what is wrong?
Aug 26 18:50:08 2012 (20033.070000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 18:42:38 2012 (19582.860000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 18:42:10 2012 ERR 2012-08-26T18:42:10Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 18:28:42 2012 (18747.030000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 18:28:18 2012 ERR 2012-08-26T18:28:18Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 18:28:10 2012 (18715.090000) danube_dsl_ioctl:88: Failed ioctl 290 errno 61
Aug 26 18:20:41 2012 (18265.280000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 18:19:37 2012 (18201.410000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 18:19:03 2012 ERR 2012-08-26T18:19:03Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 18:10:11 2012 (17635.290000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 18:09:37 2012 ERR 2012-08-26T18:09:37Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 17:32:04 2012 (15348.990000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 17:31:56 2012 (15341.140000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:31:39 2012 (15323.510000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:31:08 2012 (15292.660000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 17:30:40 2012 ERR 2012-08-26T17:30:40Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 17:30:40 2012 (15264.310000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:30:21 2012 (15245.930000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:30:14 2012 (15238.420000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:30:06 2012 (15230.640000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:29:59 2012 (15224.110000) Admin login FAILED by 192.168.1.67 on HTTP
Aug 26 17:24:16 2012 (14880.980000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 17:23:43 2012 ERR 2012-08-26T17:23:43Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 16:53:03 2012 (13008.090000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 16:52:35 2012 ERR 2012-08-26T16:52:35Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 16:17:40 2012 (10885.120000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 16:17:17 2012 ERR 2012-08-26T16:17:17Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 14:30:19 2012 ( 4443.810000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 14:20:27 2012 ( 3851.950000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 14:19:58 2012 ERR 2012-08-26T14:19:58Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 13:46:19 2012 ( 1804.180000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 13:45:50 2012 ERR 2012-08-26T13:45:50Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 13:43:53 2012 ( 1657.510000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 13:25:29 2012 ( 553.460000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 13:24:56 2012 ERR 2012-08-26T13:24:56Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 13:21:02 2012 ( 287.000000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 13:20:56 2012 ( 281.230000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 13:20:33 2012 ERR 2012-08-26T13:20:33Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 13:18:24 2012 ( 129.170000) HTTP server returned error 404
Aug 26 13:18:21 2012 ( 126.070000) HTTP server returned error 404
Aug 26 13:18:17 2012 ( 122.120000) WGET: Error connecting to host https://pbthdm.bt.motive.com/cwmpWeb/CPEMgt (66.193.112.93:443)
Aug 26 13:17:43 2012 ( 110.120000) danube_dsl_ioctl:88: Failed ioctl 290 errno 61
Aug 26 13:17:30 2012 ( 97.250000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 13:17:23 2012 ( 89.820000) HTTP server returned error 404
Aug 26 13:17:22 2012 ( 88.880000) HTTP server returned error 404
Aug 26 13:16:55 2012 ERR 2003-01-01T00:00:40Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 13:16:55 2012 ( 62.260000) HTTP server returned error 404
Aug 26 13:16:42 2012 ( 49.280000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Aug 26 13:16:42 2012 ( 49.280000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Aug 26 13:16:42 2012 ( 49.280000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Aug 26 13:16:42 2012 ( 49.280000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Aug 26 13:16:42 2012 ( 49.170000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Aug 26 13:16:42 2012 ( 49.170000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Aug 26 13:16:42 2012 ( 49.170000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Aug 26 13:16:42 2012 ( 49.170000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Aug 26 13:16:23 2012 ( 30.120000) DVA started
Aug 26 13:16:22 2012 ( 28.790000) sys_if_stats_reset failed for atm0
6 REPLIES 6
Guru
Guru
Message 2 of 7
Re: connection lost
Hi,
Welcome to BT Retail's Community Forum. This is a customer to customer forum.
Do you have any Internet connection at all?
To help us find the problem with your connection please may you see the following steps below:
1) Are you connected by master or test socket?.
2) Can you please run a BT speed test (including IP Profile) http://speedtester.bt.com (not beta version)[Best done with a wired, ethernet, connection]
3) is there any noise on your line. dial 17070 option2 from landline. should be silent but slight hum normal on cordless phone.
4) please post adsl line statistics
ADSL Line Statistic Help:
If you have a BT Home Hub like the one below...
Then:
1) Go to http://192.168.1.254 or http://bthomehub.home
2) click Settings
3) Click Advanced Settings
4) Click Broadband
5) Click Connection or sometimes called ADSL (see picture Below)
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3)
There are more useful links on Keith's website here: If you have an ADSL connection, please select this link
cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Newbie
Message 3 of 7
Re: connection lost
yes, i have internet connection, but i lost this connection many times an  hour
adsl:
Line state Connected
Connection time 0 days, 05:54:33
Downstream 8,257 Kbps
Upstream 798 Kbps
ADSL Settings
VPI/VCI 0/38
Type PPPoA
Modulation G.992.5 Annex A
Latency type Interleaved
Noise margin (Down/Up) 2.5 dB / 4.7 dB
Line attenuation (Down/Up) 47.0 dB / 24.1 dB
Output power (Down/Up) 12.3 dBm / 1.6 dBm
im connected by master socket
download speed 6.0
upload speed 0,47
ping   76,53
Guru
Guru
Message 4 of 7
Re: connection lost
Hi,
Your line is rougthly 3.4km long which I would have estimated a speed between 5.5-6.4mb on adsl2+ on a good line.
Your sync rate (the speed between the hub/router and the exchange) is  8,257 Kbps (about 8.15mbps) which is very good for your line length.
However your noise margin is low, it should be around 6dB. This could be caused by your internal wiring.
Please can you connect to the test socket by doing the follwing:
1) If you have a master socket like the ones below:
Then:
A)Carefully unscrew the bottom removable faceplate of the master socket.
B) A test socket will be revealed behind the faceplate you have just taken off.
C) plug a micro filter ,with the router, into the test socket.
This will eliminate your internal wiring.
2) get a phone and connect to the phone socket of the microfilter in the test socket and dial 17070 option 2 called quite line test. There should be no noise but slight hum normal for cordless phones.
3) Please repost all of the adsl line statistics from when connected to Test Socket. You may need to click More Details.
cheers
Try a Search
Message 5 of 7
Re: connection lost
could you also post all the errors including the ones when you click on show more detail
Newbie
Message 6 of 7
Re: connection lost
more details? where? 🙂
next event log:
Aug 26 20:08:15 2012 (24719.750000) Admin login successful by 192.168.1.67 on HTTP
Aug 26 19:44:47 2012 (23312.190000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 19:44:33 2012 (23298.000000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Aug 26 19:44:33 2012 (23298.000000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Aug 26 19:44:33 2012 (23298.000000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Aug 26 19:44:33 2012 (23298.000000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Aug 26 19:44:33 2012 (23297.950000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Aug 26 19:44:33 2012 (23297.950000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Aug 26 19:44:33 2012 (23297.950000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Aug 26 19:44:33 2012 (23297.950000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Aug 26 19:44:03 2012 ERR 2012-08-26T19:44:03Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 19:43:57 2012 (23262.090000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Aug 26 19:43:57 2012 (23262.090000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Aug 26 19:43:57 2012 (23262.090000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Aug 26 19:43:57 2012 (23262.090000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Aug 26 19:43:57 2012 (23261.980000) danube_dsl_ioctl:88: Failed ioctl 250 errno 22
Aug 26 19:43:57 2012 (23261.980000) danube_dsl_ioctl:88: Failed ioctl 255 errno 22
Aug 26 19:43:57 2012 (23261.980000) danube_dsl_ioctl:88: Failed ioctl 290 errno 22
Aug 26 19:43:57 2012 (23261.980000) danube_dsl_ioctl:88: Failed ioctl 270 errno 22
Aug 26 19:42:47 2012 (23191.750000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 19:42:23 2012 ERR 2012-08-26T19:42:23Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 19:39:26 2012 (22990.400000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 19:39:00 2012 ERR 2012-08-26T19:39:00Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 19:30:31 2012 (22455.730000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 19:30:01 2012 ERR 2012-08-26T19:30:01Z cwmp: mt_cwmp: session error: Could not resolve host
Aug 26 19:12:30 2012 (21374.340000) RTNL: Received ERROR reply 'No such process' for message type 0x19
Aug 26 19:11:58 2012 ERR 2012-08-26T19:11:58Z cwmp: mt_cwmp: session error: Could not resolve host
Guru
Guru
Message 7 of 7
Re: connection lost
To View all HEC, CRC, FEC errors on the ADSL Line Statistics you will need to click More Details.
For example:
Which Hub are you using?
There's more help on getting the adsl line statistics here: ADSL Statistics
Could you please also see my last post here: http://community.bt.com/t5/BB-Speed-Connection-Issues/connection-lost/m-p/615348/highlight/true#M152...
cheers
Try a Search
