ladysmith
Message 1 of 6
connection speed
can i pick your brains please, my broadband speed is currently 0.6mbps, estimated i could get 8.0mbps.  Its connected by extension to the telephone line, its never been superfast but the last week it's dropped so much going mad have i done something wrong in setting it up.  Not very technical minded!
5 REPLIES 5
Message 2 of 6
Re: connection speed
welcome to the BT community forum where customers help customers
in order for the forum members to help please can you post the   adsl stats  from your router may need to 'show detail' to get all stats (if hub enter 192.168.1.254 in your browser and navigate to adsl or use a-z, if netgear enter 192.168.0.1) and run btspeedtester (MAC users may have problems) bt speedtester  and post the results .
are you connected directly via a filter to the NTE5 master or test socket or to somewhere else? Is the master the only phone socket in your home?
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 6
Hi Welcome to the forums
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
also post your full hub stats details shown in this link http://www.btinternet.com/~cbeddoe/others/adslstats.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket   Test Socket.jpg
This is a customer to customer self help forum the only BT presence here are the forum moderators
ladysmith
Message 4 of 6
hi decided to try something and restarted the hub connection level has gone up from what it was to 2.7, why did that work
Message 5 of 6
must have reduced the noise margin slightly but still a long way short of your expected 8mb.  I suggest you post the router stats for the forum members to help you
Message 6 of 6
hi can you please post the information asked for we can help further then
without having seen your hub stats be fore and after the speed change it is hard to say what happened
