Message 1 of 6
connection
Hi having issues with connection. Have the new hub 6 and this only started yesterday, I have had to wait ages for my sign in to the community to post this message, any ideas what I can do please? there are no issues in this area have checked that also, but it is taking far too long to connect to anything.
Many thanks in anticipation.
5 REPLIES 5
Message 2 of 6
Re: connection
Wired or wireless?
Only on one device or all connected devices?
What router were you using before the smart hub?
Message 3 of 6
Re: connection
Hi it would appear it was the rapport trusteer security that I had downloaded, have uninstalled it now and things seem to be okay, don't know if anyone knows why this should be?
many thanks
Moderator
Moderator
Message 4 of 6
Re: connection
Thanks for letting us know you got this sorted @polish
Cheers
David
Message 5 of 6
Re: connection
thanks David for marking as accepted solution, but wondered if anyone has had issues with Rapport Trusteer?
Recognised Expert
Message 6 of 6
Re: connection
I had issues with it 3 years ago when I installed it - slowed browsing down a lot. Back then it was a resource hog apparently but I removed it and things went back to normal - I have never reinstalled it.
