purestkarma
Message 1 of 10
constant disconnects almost hourly
Hi,
I have BT infinity 2 installed and im very happy with the speed. However since the european fibre connection went down a week or two ago that effected routing from england to europe my inifinity connection seems to disconnect almost hourly.  This is incredibly frustrating as i both work from home and i am also an online gamer.
The power and wireless lights remain blue while the broadband light flashes purple/red and i have to do an automatic set up on the home hub page to get the internet up and running again.  This is incredibly frustrating.
Im based in the SS3 part of Essex.
If you need further info then please do let me know.
S.
9 REPLIES 9
Distinguished Expert
Message 2 of 10
Re: constant disconnects almost hourly
to see if its dhcp related just set your pc to have a static ip address
Guru
Message 3 of 10
while the broadband light flashes purple/red  Doesn't sound like a dhcp issue.
Do the modem lights show anything odd while the HomeHub is flashing like this?  Presumably there isn't an issue with the modem though, if just resetting the HomeHub gets everything working again.
purestkarma
Message 4 of 10
My apologies for not getting back to you sooner i have been monitoring the lights.  Basically the black hub unit switches to an orange light and complete loss of internet to all devices connected ie iphone, pc wired into hub, and a secondary pc  - which are all wired into the unit.  The white unit presumably the modem stays the same throughout without dsl, lan 1 and power lights remaining green.
If i go through the motions in hub manager of automatic setup of username it will reconnect after a minute or 4 about 80% of the time. The other 20% of the time i can only get the internet back by switching off power to the hub and modem and restarting it all.
Its driving me virtually insane.
Message 5 of 10
are there any errors reported in the router log?
purestkarma
Message 6 of 10
Heres there hub event log.
5:59:58,28 Sep.     Device connected: IP 192.168.1.64, MAC 90:E6:BA:CB:65:E5, host vindaloo-PC
  15:59:58,28 Sep.     DHCP Lease issued for IP 192.168.1.64 to host vindaloo-PC (MAC 90:E6:BA:CB:65:E5), duration: 1 day
  15:59:58,28 Sep.     Receive a DHCP request: 192.168.1.64, 90:E6:BA:CB:65:E5.
  15:59:52,28 Sep.     LAN1 up
  15:59:51,28 Sep.     LAN1 down
  15:59:28,28 Sep.     LAN1 up
  15:59:26,28 Sep.     Device disconnected: IP 192.168.1.64, MAC 90:E6:BA:CB:65:E5, host vindaloo-PC
  15:59:26,28 Sep.     LAN1 down
  15:58:10,28 Sep.     Client disassociated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Reason Code 3
  15:58:05,28 Sep.     Client associated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Link Rate 54.0 Mbps
  15:58:05,28 Sep.     DHCP Lease issued for IP 192.168.1.65 to host room101s-iPhone (MAC 00:1F:F3:EA:BA:A6), duration: 1 day
  15:58:05,28 Sep.     Receive a DHCP request: 192.168.1.65, 00:1F:F3:EA:BA:A6.
  15:57:58,28 Sep.     Client disassociated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Reason Code 3
  15:57:54,28 Sep.     DHCP Lease issued for IP 192.168.1.65 to host room101s-iPhone (MAC 00:1F:F3:EA:BA:A6), duration: 1 day
  15:57:54,28 Sep.     Receive a DHCP request: 192.168.1.65, 00:1F:F3:EA:BA:A6.
  15:57:53,28 Sep.     Client associated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Link Rate 54.0 Mbps
  15:57:52,28 Sep.     Receive a DHCP request: 192.168.1.65, 00:1F:F3:EA:BA:A6.
  15:53:08,28 Sep.     Client associated: IP 192.168.1.67, MAC F0:7B:CB:0C:A4:BB, host umugumma-R519-R719, Link Rate 65.0 Mbps
  15:53:04,28 Sep.     Client disassociated: IP 192.168.1.67, MAC F0:7B:CB:0C:A4:BB, host umugumma-R519-R719, Reason Code 4
  15:46:07,28 Sep.     DHCP Lease issued for IP 192.168.1.67 to host umugumma-R519-R719 (MAC F0:7B:CB:0C:A4:BB), duration: 1 day
  15:46:07,28 Sep.     Receive a DHCP request: 192.168.1.67, F0:7B:CB:0C:A4:BB.
  15:45:11,28 Sep.     Client associated: IP 192.168.1.67, MAC F0:7B:CB:0C:A4:BB, host umugumma-R519-R719, Link Rate 65.0 Mbps
  15:45:11,28 Sep.     DHCP Lease issued for IP 192.168.1.67 to host umugumma-R519-R719 (MAC F0:7B:CB:0C:A4:BB), duration: 1 day
  15:45:11,28 Sep.     Receive a DHCP request: 192.168.1.67, F0:7B:CB:0C:A4:BB.
  15:44:20,28 Sep.     CWMP:GPV completed successfully
  15:44:18,28 Sep.     CWMP:session completed successfully
  15:44:17,28 Sep.     CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 6 CONNECTION REQUEST
  15:44:17,28 Sep.     HTTP authentication success from 64.186.182.xxx
  15:44:17,28 Sep.     HTTP authentication Fail from 64.186.182.xxx
  15:44:15,28 Sep.     PortMapping Add By UPNP/TR064 Success.
  15:44:14,28 Sep.     CWMP:session completed successfully
  15:44:13,28 Sep.     CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 6 CONNECTION REQUEST
  15:44:13,28 Sep.     HTTP authentication success from 64.186.182.xxx
  15:44:13,28 Sep.     HTTP authentication Fail from 64.186.182.xxx
  15:44:12,28 Sep.     HTTP Recv authorization success respond from:66.193.112.xx
  15:44:10,28 Sep.     HTTP Recv authorization failed respond from:66.193.112.xx
  15:44:09,28 Sep.     CWMP:session completed successfully
  15:44:08,28 Sep.     CWMP:session start now, server:https://pbthdm.bt.mo, Event code:, 4 VALUE CHANGE, 1 BOOT
  15:44:04,28 Sep.     CWMP: Notify message from WAN Up
  15:44:03,28 Sep.     Client associated: IP 192.168.1.66, MAC 30:69:4B:DA:90:FC, host BLACKBERRY-F406, Link Rate 6.0 Mbps
  15:44:01,28 Sep.     Device connected: IP 192.168.1.68, MAC 00:1D:60:61:34:21, host user-PC
  15:44:01,28 Sep.     Device connected: IP 192.168.1.64, MAC 90:E6:BA:CB:65:E5, host vindaloo-PC
  15:43:58,28 Sep.     Possible PS or DA. src=90.184.203.143 DST=86.144.154.19 LEN=48 TOS=0x18 PREC=0x60 TTL=114 ID=58975 DF PROTO=TCP SPT=11560 DPT=62633 WINDOW=65535 RES=0x00 SYN URGP=0 OPT (0204058401010402)
  15:43:57,28 Sep.     LAN3 up
  15:43:55,28 Sep.     LAN1 up
  15:43:54,28 Sep.     WAN Auto-sensing detected port ETH
  15:43:54,28 Sep.     WAN Auto-sensing last connection port: ETH
  15:43:53,28 Sep.     NTP synchronization success!
  15:43:53,28 Sep.     NTP synchronization start.
  00:00:53,01 Jan.     WAN connection WAN4_TR069_INTERNET_R_ETH1 connected.
  00:00:50,01 Jan.     PPP IPCP Receive Configuration ACK
  00:00:50,01 Jan.     PPP IPCP Send Configuration Request
  00:00:50,01 Jan.     PPP IPCP Receive Configuration Reject
  00:00:50,01 Jan.     PPP IPCP Receive Configuration NAK
  00:00:50,01 Jan.     PPP IPCP Send Configuration ACK
  00:00:50,01 Jan.     PPP IPCP Receive Configuration Request
  00:00:50,01 Jan.     HTTP User Basic login from 192.168.1.64 successfully.
  00:00:50,01 Jan.     PPP CHAP receive success: authentication ok
  00:00:48,01 Jan.     PPP CHAP Receive Challenge
  00:00:48,01 Jan.     PPP LCP Receive Configuration ACK
  00:00:48,01 Jan.     PPP LCP Send Configuration Request
  00:00:48,01 Jan.     PPP LCP Receive Configuration Reject
  00:00:48,01 Jan.     PPP LCP Send Configuration ACK
  00:00:48,01 Jan.     PPP LCP Receive Configuration Request
  00:00:42,01 Jan.     DHCP Lease issued for IP 192.168.1.66 to host BLACKBERRY-F406 (MAC 30:69:4B:DA:90:FC), duration: 1 day
  00:00:42,01 Jan.     Receive a DHCP request: 192.168.1.66, 30:69:4B:DA:90:FC.
  00:00:41,01 Jan.     WAN connection WAN2_INTERNET_B_ETH2 connected.
  00:00:41,01 Jan.     Gigabit Ethernet Link Up, Rate: 100Mbps
  00:00:41,01 Jan.     System up, firmware version:V100R001C01B031SP12_L_B
  00:00:35,01 Jan.     NTP synchronization fail!
  00:00:35,01 Jan.     NTP synchronization start.
  00:00:24,01 Jan.     WiFi auto selected 20M channel 1 (Power-up)
  00:00:24,01 Jan.     1-86, 2::2-85, 0::3-84, 0::4-85, 0::5-85, 0::6-85, 8::7-85, 0::8-84, 0::9-83, 0::10-83, 3::11-85, 3::12-84, 0::13-84, 3
  00:00:19,01 Jan.     DHCP Lease issued for IP 192.168.1.68 to host user-PC (MAC 00:1D:60:61:34:21), duration: 1 day
  00:00:19,01 Jan.     Receive a DHCP request: 192.168.1.68, 00:1D:60:61:34:21.
  00:00:18,01 Jan.     WiFi Up
  00:00:18,01 Jan.     Receive a DHCP request: 192.168.1.68, 00:1D:60:61:34:21.
  00:00:18,01 Jan.     DHCP Lease issued for IP 192.168.1.64 to host vindaloo-PC (MAC 90:E6:BA:CB:65:E5), duration: 1 day
  00:00:18,01 Jan.     Receive a DHCP request: 192.168.1.64, 90:E6:BA:CB:65:E5.
  00:00:18,01 Jan.     WiFi Down
  15:38:11,28 Sep.     Client associated: IP 192.168.1.66, MAC 30:69:4B:DA:90:FC, host BLACKBERRY-F406, Link Rate 1.0 Mbps
  15:38:10,28 Sep.     DHCP Lease issued for IP 192.168.1.66 to host BLACKBERRY-F406 (MAC 30:69:4B:DA:90:FC), duration: 1 day
  15:38:10,28 Sep.     Receive a DHCP request: 192.168.1.66, 30:69:4B:DA:90:FC.
  15:27:14,28 Sep.     Client disassociated: IP 192.168.1.66, MAC 30:69:4B:DA:90:FC, host BLACKBERRY-F406, Reason Code 4
  15:27:09,28 Sep.     Client disassociated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Reason Code 3
  15:26:45,28 Sep.     Client associated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Link Rate 54.0 Mbps
  15:26:45,28 Sep.     DHCP Lease issued for IP 192.168.1.65 to host room101s-iPhone (MAC 00:1F:F3:EA:BA:A6), duration: 1 day
  15:26:45,28 Sep.     Receive a DHCP request: 192.168.1.65, 00:1F:F3:EA:BA:A6.
  15:18:03,28 Sep.     Client disassociated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Reason Code 3
  15:17:58,28 Sep.     Client associated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Link Rate 6.0 Mbps
  15:17:58,28 Sep.     DHCP Lease issued for IP 192.168.1.65 to host room101s-iPhone (MAC 00:1F:F3:EA:BA:A6), duration: 1 day
  15:17:58,28 Sep.     Receive a DHCP request: 192.168.1.65, 00:1F:F3:EA:BA:A6.
  15:17:39,28 Sep.     Client disassociated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Reason Code 3
  15:17:35,28 Sep.     Client associated: IP 192.168.1.65, MAC 00:1F:F3:EA:BA:A6, host room101s-iPhone, Link Rate 48.0 Mbps
purestkarma
Message 7 of 10
Any ideas anyone?
Message 8 of 10
looks like a line problem causing the disconnects but you cant rule out a dodgy router
do you have another router you can try?
purestkarma
Message 9 of 10
No sadly i dont have a spare router.
Message 10 of 10
you should either buy one or go through the mill of raising faults and getting engineers to visit in my opinion
