Alan63
Expert
Message 21 of 77
Re: contract is 76 mbps i get 38 mbps
I don't see the problem being outside, as your profile is spot on.
to my thinking you,ve a problem after  the open reach box.
you had an engineer in you house to look at that?
Deathtrap3000
Recognised Expert
Message 22 of 77
+1
Ratty2012
Recognised Expert
Message 23 of 77
If you look at the videos of the speedtest he has, you can see the speed how the speed flutuates, this indicates errors on the line that the modem is trying to compinsate for.
Storm
Expert
Message 24 of 77
@toekneem wrote:
@Storm wrote:
It is only UP TO in the sense it is UP TO and no more than 76Mb, the service you are sold is not UP TO anything it is plainly stated as SHOULD be X up, Y down and GENERALLY within +/- 1 or 2Mb of X up,Y down.
Not as people would have you believe UP TO the figures sold!!!
Your entitled to your opinion.
So now you should be able to go to a county court and get your 76Mb +/-1 or 2Mb.Smiley Wink
It's not an opinion it's a fact.
You are missing the point, I was sold 48.9Mb down 10.9Mb up not 76Mb down 20Mb up hence I do not expect 76Mb down 20Mb up.
As I said the service is up to 76Mb but in reallity it is sold to me as a definitve level of 48.9Mb down, 10.9Mb up which I do expect i.e. In my case I SHOULD get 48.9Mb GENERALLY within +/- 1 or 2 Mb, it does not state UP TO 48.9Mb.
As I've said countless times if you are happy to pay for something you are promised then don't receive then I'm really happy for you, just don't bang on at people who are not in the same frame of mind.
ghostzz
Message 25 of 77
personally i think the home hub is piece of **bleep**e 1 gigabit port and its not even for the connection between hh3 and white box so thats where i think the problem
Ratty2012
Recognised Expert
Message 26 of 77
To rule out the hub once and for all, you can connect direct to the modem
Alan63
Expert
Message 27 of 77
That's a good point- connect direct. Eliminnate a variable And see if you get near your profile
ghostzz
Message 28 of 77
okay how do i that? i am guessing i can't just take the black wire and shove it in
Alan63
Expert
Message 29 of 77
ghostzz
Message 30 of 77
followed the soloution this was the http://62.6.38.125/index.html
