Andy_N
Distinguished Guru
Message 11 of 77
Re: contract is 76 mbps i get 38 mbps
https://www.youtube.com/watch?v=u0isumJip_8
Hi. The video clearly shows that the contract is "up to 76Mbps" as others have indicated.
The video speeds as shown may indicate that your connection could be stuck at "normal infinity". Can you post the hub stats which should give details of the connection.
How is your computer connected to the hub, is it wireless or ethernet ? Many wireless connections (and indeed older wireless adaptors) will not be able to deliver the higher speeds. This is something else that needs checking (e.g. wireless "n") - since I believe that wireless "g" only supports up to 54Mbps, and even then it's theoretical maximum values. There are many other variables that can seriously interfere with the speeds - e.g. distance, interference from external sources etc.
ghostzz
Message 12 of 77
look at the of day
they've said my line capable of upto 76 mbps yet i get no where near that
i am stuck under 40 mbps
plainview
Recognised Expert
Message 13 of 77
Then they have either set your profile to that of Infinity 1 by mistake or there maybe a line fault.
Have you called BT about it because they aren't mind readers, they used to be but due to competition laws being introduced to make it a fair playing field for other CP's they had it taken away from them.
Ratty2012
Recognised Expert
Message 14 of 77
Are you using a wired connection for your speedtest or a wireless one?
dylanere
Message 15 of 77
My favourite christmas song 🙂 🙂 Are you sure you're wired while doing this test? The upload is to high so you're not accidently on infinity 1.
Storm
Expert
Message 16 of 77
It is only UP TO in the sense it is UP TO and no more than 76Mb, the service you are sold is not UP TO anything it is plainly stated as SHOULD be X up, Y down and GENERALLY within +/- 1 or 2Mb of X up,Y down.
Not as people would have you believe UP TO the figures sold!!!
toekneem
Distinguished Guru
Message 17 of 77
Your entitled to your opinion.
So now you should be able to go to a county court and get your 76Mb +/-1 or 2Mb.Smiley Wink
toekneem
(EASBF)
ghostzz
Message 18 of 77
do you think i am retarded or something
ofcourse i am using a wired connection i am speedtester.jpgcat 5 cable connect to the gigabit port of the home hub
Alan63
Expert
Message 19 of 77
Indicates a prob with the router.you contacted the mods?
ghostzz
Message 20 of 77
had mutiple routers(homehubs) and modems(whitebox)
someone said the problem could be between my home and the cabnet wiring
that a specilist team would be required
distant between my home and cabinet is couple of hundred ft
and the distant between my home and exchange is 0.8 miles
