staking
Message 1 of 4
data usage not updated from yesturday ?
according to my usage data
Last usage update:23 May 2011 at 23:59
it wasn't updated yesturday, how come ?  i keep a eye on this so i dont go over my 40gb limit.
3 REPLIES 3
Izzy
Message 2 of 4
Re: data usage not updated from yesturday ?
Same here, mine also stuck on 23 May 2011 at 23:59...
staking
Message 3 of 4
Re: data usage not updated since 23 May !!!!
data usage still stuck at
what is going on BT ?
What happens if i go over my limit due to bt not updating there user data usage ??
Moderator-Retired
Message 4 of 4
Hi guys,
We're aware of a problem and it's currently being looked into. Once we get updates we'll post in this thread.
Cheers
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
