willwas
Newbie
Message 1 of 3
default email is wrong..
can anyone tell me why when i am using an application that finds my email and opens it for sending say a picture or a file i have compressed to send does it always find my windows live or google mail instead of my bt yahoo one..thanks... i hope this is the place to put this...
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: default email is wrong..
I don't believe the programs are capable of picking up a web address .  I might be wrong.
The only way to send that is once you have edited /compressed the file save it somewhere on you PC, then open webmail and import it/attach to your message
toekneem
(EASBF)
Distinguished Guru
Message 3 of 3
If you do all your email through an email client on Windows, then check which of the email accounts is set as the "default".  This will be in the setting of the client (it's under Tools->Accounts in Outlook Express).
If you use webmail, then the application will have no idea how to use it.
