spar
Message 1 of 7
deposit files
deposit files
is bt blocking this site or is there a problem?
works from my remote server on diff isp but not bt
mod can u please answer
thank you
6 REPLIES 6
Distinguished Guru
Message 2 of 7
Re: deposit files
@spar wrote:
deposit files
thank you
Hi, if you do a search you will find this:
http://community.bt.com/t5/BB-Speed-Connection-Issues/Are-BT-blocking-depositfiles/td-p/239549
toekneem
(EASBF)
spar
Message 3 of 7
Re: deposit files
ah thanks and yes i have a 86.*
bt should sort this out asap!
spar
Message 4 of 7
Re: deposit files
bt if u dont fix this i will use it as a fails to meet standards  advertised , not fit for use etc whatever to cancel out of contract
Distinguished Guru
Message 5 of 7
Re: deposit files
Hi.
I think you might find that some 86* Ip's can connect to it. In one of my earlier posts on the subject i was using a 86* ip and could connect when the poster said he couldn't.
toekneem
(EASBF)
spar
Message 6 of 7
Re: deposit files
hmm well i have tried about 6 diff ips all starting with 86.*
each fails
so if its not a ip issue
something else is messed up
hmm just checked now and all ok sam 86.* ip as last night.
mailed the mods not got a reply but now it works, interesting
rationalzombie
Message 7 of 7
Re: deposit files
you won't like him when he's angry ^^
If I helped, then consider clicking the star to the left
