shamus1
Expert
Message 1 of 21
disconnection
hi i have just lost connection briefly router went orange and reconnected after looking at logs it wasnt a full reset something to do with ppoa anyone any ideas as why as it randomly does this
Time and date Message
17:31:26, 07 Dec.(109859.630000) WAN operating mode is DSL
17:31:26, 07 Dec.(109859.630000) Last WAN operating mode was DSL
17:31:26, 07 Dec.(109859.590000) PPPoA is up -​ VPI: 0, VCI:38
17:31:25, 07 Dec.(109858.740000) PPP IPCP Receive Configuration ACK
17:31:25, 07 Dec.(109858.730000) PPP IPCP Send Configuration Request
17:31:25, 07 Dec.(109858.720000) PPP IPCP Receive Configuration NAK
17:31:25, 07 Dec.(109858.720000) PPP IPCP Send Configuration ACK
17:31:25, 07 Dec.(109858.720000) PPP IPCP Receive Configuration Request
17:31:25, 07 Dec.(109858.710000) PPP IPCP Send Configuration Request
17:31:25, 07 Dec.(109858.710000) CHAP authentication successful
17:31:24, 07 Dec.(109857.200000) CHAP Receive Challenge
17:31:24, 07 Dec.(109857.200000) Starting CHAP authentication with peer
17:31:24, 07 Dec.(109857.200000) PPP LCP Receive Configuration ACK
17:31:24, 07 Dec.(109857.190000) PPP LCP Send Configuration Request
17:31:24, 07 Dec.(109857.190000) PPP LCP Receive Configuration Reject
17:31:24, 07 Dec.(109857.180000) PPP LCP Send Configuration ACK
17:31:24, 07 Dec.(109857.180000) PPP LCP Receive Configuration Request
17:31:22, 07 Dec.(109855.250000) PPP LCP Send Configuration Request
17:30:48, 07 Dec.(109821.800000) PPPoA is down after 1828 minutes
20 REPLIES 20
shamus1
Expert
Message 2 of 21
Re: disconnection
adsl stats dont show a restart
1. Product name:BT Home Hub
2. Serial number:+076270+NQ31872012
3. Firmware version:Software version 4.7.5.1.83.8.130.1.17 (Type A) Last updated 14/05/14
4. Board version:BT Hub 4A
5. ADSL uptime:1 days, 06:54:42
6. Bandwidth:1171 / 19736
7. Data sent/received:19.3 MB / 73.7 MB
8. Broadband username:bthomehub@btbroadband.com
9. BT FON:No
10. 2.4 GHz Wireless network/SSID:BTHub4-TRP2
11. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (Recommended)) 20 MHz, WPS enabled
12. 2.4 GHz Wireless security:WPA and WPA2
13. 2.4 GHz Wireless channel:Automatic / 1
14. 5 GHz Wireless network/SSID:BTHub4-TRP2
15. 5 GHz Wireless connections:Enabled (802.11 n 40 MHz (Recommended)) 20/40 MHz, WPS enabled
16. 5 GHz Wireless security:WPA2
17. 5 GHz Wireless channel:Automatic / 40
18. Firewall:Default
19. MAC Address:cc:33:bb:10:bf:96
20. VPI/VCI:0 / 38
21. Modulation:G.992.5 Annex A
22. Latency type:Fast
23. Software variant:-
24. Boot loader:-
BT Home Hub
john46
Message 3 of 21
Re: disconnection
just a temporary loss of authentication
shamus1
Expert
Message 4 of 21
Re: disconnection
thanks john but could you explain a bit more if you can thanks.
john46
Message 5 of 21
Re: disconnection
a temporary loss of connection to BT's authentication server
this link may help http://en.wikipedia.org/wiki/Authentication_server
shamus1
Expert
Message 6 of 21
Re: disconnection
thanks john for that,i had been in touch with the mods about getting my fon switched off and they said there was a problem with credentials, could there still be a problem,heres the email i received from a mod
I have ceased the service for BT Wifi for you and I have also opted your Home Hub out of BT Wifi/Fon. There was an issue with the credentials from your Hub writing back to us which is why you could not successfully opt your Hub out. My change has fixed that. This can take up to 5 weeks, maximum, however the change I made should hopefully have opted your Hub out of this from today. Let me know if you need me.
do you think i still have a problem somewhere as this isnt the first time this loss of pppoa has happened?
john46
Message 7 of 21
Re: disconnection
pppoa losses happen from time to time i would not over worry about it
shamus1
Expert
Message 8 of 21
Re: disconnection
well its happening more often now.......
07:30:47, 09 Dec.(246618.640000) WAN operating mode is DSL
07:30:47, 09 Dec.(246618.640000) Last WAN operating mode was DSL
07:30:46, 09 Dec.(246618.600000) PPPoA is up -​ VPI: 0, VCI:38
07:30:46, 09 Dec.(246617.740000) PPP IPCP Receive Configuration ACK
07:30:46, 09 Dec.(246617.730000) PPP IPCP Send Configuration Request
07:30:46, 09 Dec.(246617.720000) PPP IPCP Receive Configuration NAK
07:30:46, 09 Dec.(246617.720000) PPP IPCP Send Configuration ACK
07:30:46, 09 Dec.(246617.720000) PPP IPCP Receive Configuration Request
07:30:46, 09 Dec.(246617.710000) PPP IPCP Send Configuration Request
07:30:46, 09 Dec.(246617.710000) CHAP authentication successful
07:30:43, 09 Dec.(246615.370000) CHAP Receive Challenge
07:30:43, 09 Dec.(246615.370000) Starting CHAP authentication with peer
07:30:43, 09 Dec.(246615.370000) PPP LCP Receive Configuration ACK
07:30:43, 09 Dec.(246615.360000) PPP LCP Send Configuration Request
07:30:43, 09 Dec.(246615.360000) PPP LCP Receive Configuration Reject
07:30:43, 09 Dec.(246615.360000) PPP LCP Send Configuration ACK
07:30:43, 09 Dec.(246615.360000) PPP LCP Receive Configuration Request
07:30:42, 09 Dec.(246613.780000) PPP LCP Send Configuration Request
07:30:08, 09 Dec.(246580.530000) PPPoA is down after 153 minutes uptime [Disconnected]
07:30:07, 09 Dec.(246578.990000) PPP LCP Send Termination Request [Peer not responding]
04:56:16, 09 Dec.(237348.200000) WAN operating mode is DSL
04:56:16, 09 Dec.(237348.200000) Last WAN operating mode was DSL
04:56:16, 09 Dec.(237348.160000) PPPoA is up -​ VPI: 0, VCI:38
04:56:15, 09 Dec.(237347.340000) PPP IPCP Receive Configuration ACK
04:56:15, 09 Dec.(237347.330000) PPP IPCP Send Configuration Request
04:56:15, 09 Dec.(237347.330000) PPP IPCP Receive Configuration NAK
04:56:15, 09 Dec.(237347.320000) PPP IPCP Send Configuration ACK
04:56:15, 09 Dec.(237347.320000) PPP IPCP Receive Configuration Request
04:56:15, 09 Dec.(237347.310000) PPP IPCP Send Configuration Request
04:56:15, 09 Dec.(237347.310000) CHAP authentication successful
04:56:15, 09 Dec.(237347.210000) CHAP Receive Challenge
04:56:15, 09 Dec.(237347.210000) Starting CHAP authentication with peer
04:56:15, 09 Dec.(237347.210000) PPP LCP Receive Configuration ACK
04:56:15, 09 Dec.(237347.200000) PPP LCP Send Configuration Request
04:56:15, 09 Dec.(237347.200000) PPP LCP Receive Configuration Reject
04:56:15, 09 Dec.(237347.200000) PPP LCP Send Configuration ACK
04:56:15, 09 Dec.(237347.200000) PPP LCP Receive Configuration Request
04:56:15, 09 Dec.(237347.100000) PPP LCP Send Configuration Request
04:55:42, 09 Dec.(237314.050000) PPPoA is down after 2124 minutes uptime [Disconnected]
shamus1
Expert
Message 9 of 21
Re: disconnection
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:0 days, 10:59:36
Downstream:19.27 Mbps
Upstream:1.144 Mbps
shamus1
Expert
Message 10 of 21
Re: disconnection
when these disconnections happen no line noise comes up in logs after disconnection ,the last ones are
11:02:07, 06 Dec.( 101.860000) DSL noise margin: 5.90 dB upstream, 3.10 dB downstream
11:02:06, 06 Dec.( 100.830000) DSL line rate: 1171 Kbps upstream, 19736 Kbps downstream
