Hi, Keep getting ,"you are using a BT service which requires the use of BT DNS Servers and it appears you ate trying to connect using a DNS Server outside of our network". Help,I'm useless enough ob the laptop. Phones,tablets etc all work fine. Tried turning off parental controls and BT Protect but nothing is working.
I tried that previously but didn't work. Spoke to BT who said turn off BT protect,shut down then wait a minimum of 4 hours to see if that does it. I'm waiting at the moment and will post back if I have success. Thanks for help .
