Muttley_oA
Message 1 of 31
down speed is now half
So about a year ago I renewed my contract and recieved a 'smart hub' for my trouble.
After a few days I was seeing 40meg down and nearly 8meg up, which was wonderful considering I live in a small village.
So the smart hub started rebooting for no apparent reason, got worse to the point of rebooting like every hour.
So I went out and brought a Draytek 2860.
Long story short, my 40meg down speed has consistently decreased to now 22meg.
I have no idea during this time how many firmward versions Draytek has sent me, nothing has helped.
After numerous phonecalls, and to be fair they even sent an engineer to check the line, BT insist the problem is the router.
BT sent me another smart hub, but still reboots constantly and takes 15-20 mins to sync!
So I now have a Netgear D7000
VDSL LinkDownstreamUpstream
Link Rate22400 Kbps7200 Kbps
Line AttenuationD0( 19.0) D1( 52.6) D2( 82.9) dBU0( 6.4) U1( 40.8) U2(N/A) U3(N/A) U4(N/A) dB
Noise MarginD0( 14.4) D1( 14.4) D2(N/A) dBU0( 7.3) U1( 7.5) U2(N/A) U3(N/A) U4(N/A) dB
VDSL2 ProfileProfile 17a
So frustrating knowing I can get alot higher speed, even the min guaranteed speed is alot higher:
Fibre broadband
32Mb-44MbEstimated download speed* range
30MbLowest assured download speed*
Any advice on where I should go from here?
30 REPLIES 30
grahambenidorm
Message 2 of 31
Re: down speed is now half
Hello I am not sure that going out and spending dosh on another router is going to answer your problems.
I presume you are perhaps a hard core broadband user who "needs the speed" so as to speak, if not my experience of the latest BT Smart Hub is that it is suitable for most needs and this has been confirmed by both existing engineers and past engineers. There is a miriad of issues that can occur on parts of the BT network which rely on decades old copper wiring eyond the FTTC.
If you can post the advanced info from your BT  Smart Hub here there are plenty of experienced customers who can guide and help you. There is also a small dedicated team of mods who can also take ownership of your issue but they do not have magic wands nor is the solution instant. Gather as much info as you can ADSL checker, speed tests etc as well as router data and I am sure some one will help.
Good luck
XRaySpeX
Recognised Expert
Message 3 of 31
Please post your full Home Hub router stats
Learn how from here Broadband Top Tips
Full router stats are key to any speed & connection issues.
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Muttley_oA
Message 4 of 31
Thank you for your reply.
I agree about going and buying another router, but I needed to try something!
The adsl checker was interesting - seems like I am getting the impacted range B
The test date was when the engineer came out I reakon. I have a NTE mk4 faceplate fitted which is where the router is plugged into of course.
We have had FTTC since is was put in, about 2 - 3 years ago, and have enjoyed around 29megs down from then up to last year when I renewed my contract. I can't recall, but I'm sure BT said they could increase speed so I renewed and then to start with I saw the speed increase nicely up to about 41-42 megs.
It really seems that without a bt router, you don't get max possible speed, but I know this cant be right. And I do not want to go back to the smart hub which drops connection all the time.
XRaySpeX
Recognised Expert
Message 5 of 31
You may currently be getting a sync speed in the Impacted line range but the estimates you were given by BT are of a Clean line. You do have a Clean line as you have no bridge taps.
Now let's see your HH stats?
Muttley_oA
Message 6 of 31
Currently using the netgear router. stats from that any good, or do I need to replace with the smart hub and get the stats from that?
XRaySpeX
Recognised Expert
Message 7 of 31
It isn't! But most ISPs, incl. BT, will only look into issues when connected by their own router. For myself, there are some stats the HH shows that the Netgear doesn't.
conrad
Recognised Expert
Message 8 of 31
Post the netgear first. Don't replace with the smart hub yet to avoid another line disconnection
Muttley_oA
Message 9 of 31
Thanks for your help.
Here are some stats, dont know if you need more?
Stats recorded 17 Sep 2017 19:01:01
DSLAM/MSAN type: BDCM:0xb12d / v0xb12d
Modem/router firmware: AnnexA version - A2pvbH042n.d26b
DSL mode: VDSL2 Profile 17a
Status: Showtime
Uptime: 7 hours 6 min 11 sec
Resyncs: 0 (since 17 Sep 2017 19:00:29)
Downstream Upstream
Line attenuation (dB): 24.2 0.0
Signal attenuation (dB): Not monitored
Connection speed (kbps): 22400 7200
SNR margin (dB): 14.3 7.2
Power (dBm): 13.5 -1.4
Interleave depth: 16 1
INP: 59.00 59.00
G.INP: Enabled Enabled
Vectoring status: 5 (VECT_UNCONFIGURED)
RSCorr/RS (%): 0.0056 0.0323
RSUnCorr/RS (%): 0.0000 0.0000
ES/hour: 0 0
Muttley_oA
Message 10 of 31
This is via dslstats:
xdslctl info --stats
xdslctl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 0
Last initialization procedure status: 0
Max: Upstream rate = 8463 Kbps, Downstream rate = 46116 Kbps
Bearer: 0, Upstream rate = 7200 Kbps, Downstream rate = 22400 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 14.3 7.2
Attn(dB): 24.2 0.0
Pwr(dBm): 13.5 -1.4
VDSL2 framing
Bearer 0
MSGc: -6 -6
B: 24 131
M: 1 1
T: 0 0
R: 8 8
S: 0.0347 0.5755
L: 7611 1946
😧 16 1
I: 33 140
N: 33 140
Q: 16 1
V: 8 0
RxQueue: 126 120
TxQueue: 18 15
G.INP Framing: 18 18
G.INP lookback: 18 15
RRC bits: 24 24
Bearer 1
MSGc: 90 58
B: 0 0
M: 2 2
T: 2 2
R: 16 16
S: 10.6667 16.0000
L: 24 16
😧 1 1
I: 32 32
N: 32 32
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 0
OHFErr: 9 6
RS: 3002802896 1293068
RSCorr: 163644 540
RSUnCorr: 0 0
Bearer 1
OHF: 1627517 585252
OHFErr: 0 20
RS: 9764732 2240345
RSCorr: 6 202
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 18450 2358
rtx_c: 672 48660
rtx_uc: 559 268540
G.INP Counters
LEFTRS: 1 97
minEFTR: 22396 7198
errFreeBits: 8914322 172266523
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 1126076931 0
Data Cells: 68093978 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 2 2
SES: 0 0
UAS: 28 28
AS: 26142
Bearer 0
INP: 59.00 59.00
INPRein: 1.00 1.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 22973.89 7310.64
Bearer 1
INP: 2.50 4.00
INPRein: 2.50 4.00
delay: 0 0
PER: 16.06 16.06
OR: 47.81 31.87
AgR: 47.81 31.87
Bitswap: 6835/6897 341/342
Total time = 7 hours 16 min 10 sec
FEC: 163644 540
CRC: 9 6
ES: 2 2
SES: 0 0
UAS: 28 28
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Latest 15 minutes time = 1 min 10 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 15 minutes time = 15 min 0 sec
FEC: 325 109
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: N/A
Latest 1 day time = 7 hours 16 min 10 sec
FEC: 163644 540
CRC: 9 6
ES: 2 2
SES: 0 0
UAS: 28 28
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 1 day time = 0 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Since Link time = 7 hours 15 min 41 sec
FEC: 163644 540
CRC: 9 6
ES: 2 2
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
