Expert
Message 1 of 13
download line attenuation
router reset on own yesterday and download line attenuation has gone from 23.5 which it has always been to 34 any ideas?
homesettingsadvanced_settingstroubleshooting
Help and AdviceHelpdeskEvent Log
Information for Helpdesk agents
When contacting the BT Broadband helpdesk, the agent might ask you for details about your BT Home Hub. This page contains all of the information they are likely to request.
1. Product name:BT Home Hub
2. Serial number:+068543+NQ51954375
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 05/09/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 17:22:22
6. Data rate:7114 / 38274
7. Maximum data rate:7114 / 46450
8. Noise margin:6.1 / 8.7
9. Line attenuation:34.6 / 23.4
10. Signal attenuation:23.5 / 20.9
11. Data sent/received:2.0 GB / 71.5 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:No
14. 2.4 GHz Wireless network/SSID:BTHub5-KXZX
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-KXZX5GHZ
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:54:64:d9:11:b3:b4
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
12 REPLIES 12
Expert
Message 2 of 13
Re: download line attenuation
17:20:24, 08 Mar.(267283.500000) PPP LCP Send Termination Request [User request
Message 3 of 13
34.6 is the upstream attenuation is it not? The downstream still seems to be 23.4?
Expert
Message 4 of 13
sorry you are correct so the upstream line attenuation?
Message 5 of 13
Are you saying the upstream attenuation has changed? Have you noticed a difference in your upload speeds?
Expert
Message 6 of 13
yes upload is slower and my ip profile has dropped from 38.75 to 37.05?
Expert
Message 7 of 13
Results Image not loaded
1. Best Effort Test: -provides background information.
 Download Speed
 36.29 Mbps
0 Mbps37.05 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 36.29 Mbps
 For your connection, the acceptable range of speedsis 25.93 Mbps-37.05 Mbps .
 Additional Information:
 IP Profile for your line is - 37.05 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 6.35 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 6.35Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
Message 8 of 13
Can you pop your telephone number into this checker and post the results https://www.btwholesale.com/adslchecker/ remove your telephone number before posting the results though. Small fluctuations in speed are normal with xDSL services.
Expert
Message 9 of 13
cant copy the results?
Message 10 of 13
Take a screenshot, edit the picture in paint to remove your phone number. Save the image and then upload the image.
