paulnewton2
Message 11 of 16
Re: download speed 0.12Mbps, DSL speed 6.21 Mbps
thanks - the logs above are from now - just I reset the router to drop the line and the date was not reset before the router connected
however - here's a log with the right date!
12:26:03, 04 May.( 1884.430000) Admin login successful by 192.168.1.89 on HTTP
12:26:03, 04 May.( 1883.820000) ETHoA is up - VPI: 0, VCI:35
12:26:03, 04 May.( 1883.810000) DSL is up
12:26:00, 04 May.( 1881.460000) DSL noise margin: 25.00 dB upstream, 15.10 dB downstream
12:26:00, 04 May.( 1881.390000) DSL line rate: 448 Kbps upstream, 6176 Kbps downstream
paulnewton2
Message 12 of 16
thanks - how do we clear the noise on the line given we are connected directly into the master socket?
imjolly
Message 13 of 16
was the quiet line test quiet?  if so you just need to stay connected for 3+ days 24/7 and then repost your stats provided you have managed to amintain a stable connection 24/7 the mods will help reset your noise margin - but stable conenction first
paulnewton2
Message 14 of 16
there was some noise on the quietline test - occasional crackles - it's a cordless phone, but we have a corded phone too and that gives the same problems
imjolly
Message 15 of 16
then if you noise on your line then you need to report a phone fault to 151 with no mention of broadband   get your phone fault fixed and that will help your broadband conenction
john46
Message 16 of 16
you should hear no noise if you can then it needs reporting to BT faults on 151 with no mention of broadband in the call
