dazwilemanuk
Message 11 of 17
Re: drop outs every few hours
i've had line tests done by BT and they all come back fine (or so they say). Also tried a fault test from the website and that came back fine too.....
dazwilemanuk
Message 12 of 17
 Line check result
fault help and tips links
printThisPage
Thanks for waiting, we've tested your line and here are the results.
Telephone number checkedXXXXXXXXXXXX
Results of line test
We cannot detect a problem with this line.It may be caused by a faulty phone or equipment.
legitimise_sailing
Distinguished Expert
Message 13 of 17
Am I right in thinking the only thing you have which is common across your devices is the master socket? Try a replacement
To say thanks for a helpful answer, please click the white star
dazwilemanuk
Message 14 of 17
it's a relatively new master socket - only around 18 months old
dazwilemanuk
Message 15 of 17
Finally!  a fault is acknowledged!  Hopefully something will be done about it now.
dazwilemanuk
Message 16 of 17
OK, another issue now - after finally being connected for 17 hours, the connection dropped again.
I'm connected at the moment using the old BT OR modem, and my Asus modem is connected via the WAN port:
2014-02-18 11:56:04 [Informational] syslog: No response to 10 echo-requests
2014-02-18 11:56:04 [Notice] syslog: Serial link appears to be disconnected.
2014-02-18 11:56:04 [Informational] syslog: Connect time 1022.8 minutes.
2014-02-18 11:56:04 [Informational] syslog: Sent 55254026 bytes, received 332882653 bytes.
2014-02-18 11:56:04 [Informational] syslog: LCP down.
2014-02-18 11:56:04 [Notice] syslog: Connection terminated.
2014-02-18 11:56:05 [Informational] kernel: Link State: PVC_10 logistic interface down.
2014-02-18 11:56:07 [Informational] WAN Connection: Fail to connect with some issues.
2014-02-18 11:56:07 [Informational] stop_nat_rules: apply the redirect_rules!
2014-02-18 11:56:08 [Informational] syslog: LCP is allowed to come up.
2014-02-18 11:56:24 [Debug] syslog: PADS: Service-Name: ''
2014-02-18 11:56:24 [Informational] syslog: PPP session is 331
2014-02-18 11:56:24 [Warning] syslog: Connected to a0:f3:e4:34:54:bc via interface nas10
2014-02-18 11:56:24 [Debug] syslog: using channel 4
2014-02-18 11:56:24 [Informational] syslog: Using interface ppp10
2014-02-18 11:56:24 [Notice] syslog: Connect: ppp10 <--> nas10
2014-02-18 11:56:24 [Informational] syslog: CHAP authentication succeeded: CHAP authentication success
2014-02-18 11:56:24 [Informational] syslog: CHAP authentication success
2014-02-18 11:56:24 [Notice] syslog: CHAP authentication succeeded
2014-02-18 11:56:24 [Notice] syslog: peer from calling number A0:F3:E4:34:54:BC authorized
2014-02-18 11:56:24 [Notice] syslog: local  IP address 81.129.162.8
2014-02-18 11:56:24 [Notice] syslog: remote IP address 172.16.17.6
2014-02-18 11:56:24 [Notice] syslog: primary   DNS address 213.120.234.26
2014-02-18 11:56:24 [Notice] syslog: secondary DNS address 213.120.234.10
2014-02-18 11:56:24 [Informational] kernel: firewall_execute begin
2014-02-18 11:56:24 [Informational] kernel: firewall_execute end
2014-02-18 11:56:24 [Informational] kernel: route_setting
2014-02-18 11:56:24 [Informational] kernel: open /tmp/pre_lan_route.list fail
2014-02-18 11:56:24 [Informational] kernel: open /tmp/pre_wan0_route.list fail
2014-02-18 11:56:24 [Informational] kernel: open /tmp/pre_wan0_mroute.list fail
2014-02-18 11:56:24 [Informational] kernel: ddns_execute(), DDNS is not enable, so remove /etc/ddns.conf.
2014-02-18 11:56:25 [Informational] kernel: Link State: PVC_10 logistic interface up.
2014-02-18 11:56:25 [Informational] dnsmasq[3412]: started, version 2.52 cachesize 150
2014-02-18 11:56:25 [Informational] dnsmasq[3412]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-I18N no-DHCP no-TFTP
2014-02-18 11:56:25 [Informational] dnsmasq[3412]: using nameserver 213.120.234.10#53(via ppp10)
2014-02-18 11:56:25 [Informational] dnsmasq[3412]: using nameserver 213.120.234.26#53(via ppp10)
2014-02-18 11:56:25 [Informational] dnsmasq[3412]: reading /etc/resolv.conf
2014-02-18 11:56:25 [Warning] dnsmasq[3412]: ignoring nameserver ::1 - local interface
2014-02-18 11:56:25 [Warning] dnsmasq[3412]: ignoring nameserver 127.0.0.1 - local interface
2014-02-18 11:56:25 [Informational] dnsmasq[3412]: read /etc/hosts - 4 addresses
2014-02-18 11:52:27 [Informational] WAN Connection: WAN was restored.
2014-02-18 11:52:27 [Informational] start_nat_rules: apply the nat_rules(/tmp/nat_rules)!
Problem is of course using the OR modem, i can no longer see any diagnostics about the connection - the above is from my Asus box
thanks
Regards
Darren
infinidim
Expert
Message 17 of 17
Darren, I think you might still have a line issue as it looks like the end (User CPE) to end (BRAS) session dropped somewhere in the path.
Infinidim
Megadodo Publications
Ursa Minor Beta
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side
If the the reply answers your question then please mark as ’Mark as Accepted Solution’
