After update anyone else got duplicate channels i,e 346 syfy 343 Gold etc which take you to now tv sign up ,Get now tv on Bt Tv ,bit pain have go through channels an hide them all,just add i am on max 4k package £20 month an what work out if i upgrade to new packages it is going to cost me £35 to get the same channels, would gain sky movies which i don`t want ,so will be sticking to current package,
The duplicates are the ones provided via NowTV and the ones available through BTTV packages, you can click the green button and hide channels you're not subscribed to, so if you don't have NowTV they will vanish from the EPG.
a list of channel numbers which are for now tv would be helpful which save a lot of time having to tune to each channel to check if it is active or not in your current package
Or better still, just a tick box for hide "Now TV Channels", hide "Sky Sports", hide "Sky Cinema" would be great. Or even just hide "Unsubscribed" although I think the last one would be a challenge...
Hi @jonstannes Thanks for your posts, to remove the duplicated you can follow either of these steps.
