Message 1 of 13
e-mail
I am having problems getting into my e-mail account is any work being done?
Is this anything to do with the BT Yahoo new mail which seems to have been in beta mode for ages?
If any work being done was planned it would have been nice to have been informed
12 REPLIES 12
Message 2 of 13
Re: e-mail
My mail is down again!!!!
Recognised Expert
Message 3 of 13
Re: e-mail
Yes, there seem to have been a lot of authentication failures on and off for the last couple of weeks. No idea what is going on.
The mail client logs on successfully and collects mail, but a few minutes later it fails with an authentication error. A few minutes after that it works without changing anything and so on. This is the same with both Macs and PCs in our house.
Have also experienced problems logging on to web mail recently, getting username or password errors when I know I have entered them correctly. Its completely random and seems to occur when I am in no particular location.
Message 4 of 13
Re: e-mail [failures to see BT server?]
Interesting to read these comments.   I have had a number of failures to log into my BT account over the past few days.   I can log into my second account with 12FreeUK which goes through the BT server and receive and send messages!   I use PegasusMail v4.51 and the BT Protocol Error message is [address hidden ]
[*] Connection established to 217.146.188.192
>> 0058 +OK AVG POP3 Proxy Server 8.5.401/8.5.449 [271.1.1/3669]
<< 0027 USER xxxxxxxxx@btinternet.com
>> 0024 +OK password required.
<< 0017 PASS XXXXXXXXXX
I have just tried three times and also sent a test message which appeared to be accepted and then when went to Selective mail DownLoad again lo and behold the system is working once more.
What is happening?   My exchange is Crowthorne, Berks.
Rodney Fry
Message 5 of 13
Getting the same thing today and have been on and off for the past couple of days, using Windows live mail.
Community Manager
Community Manager
Message 6 of 13
Re: e-mail
Hi Guys,
Just noticed this on the Service status page Service Status page
Further updates can be found on that page as and when they come in.
Cheers
Sean
Message 7 of 13
Re: e-mail
Thanks for letting us know, SeanD 🙂
Message 8 of 13
Re: e-mail
The problem as reported on the web page does not cover the Crowthorne area!
Wed 01/06/2011 at 09amOngoing Problem in the Kirkburton area
Dialling codes affected: 01484
Estimated time to resolve: 2hrs
We know that some of our customers in the Kirkburton area are having trouble getting online at the moment. Sorry about this. We're working to fix the problem as quickly as we can.
Wed 01/06/2011 at 10amOngoing Problem in the Thorne area
Dialling codes affected: 01405
We know that some of our customers in the Thorne area are having trouble getting online at the moment. Sorry about this. We're working to fix the problem as quickly as we can.
Wed 01/06/2011 at 10amOngoing Problem in the Sheffield area
We know that some of our customers in the Sheffield area are having trouble getting online at the moment. Sorry about this. We're working to fix the problem as quickly as we can.
Wed 01/06/2011 at 12pmOngoing Problem with BT Yahoo! Mail
We are currently investigating a reported problem with webmail. If you are affected, please bear with us. Updated messages will appear here - you may need to refresh your web page.
Wed 01/06/2011 at 01pmOngoing Problem in the Cardiff Area
Dialling codes affected: 01446
We know that some of our customers in the Cardiff area are having trouble getting online at the moment. Sorry about this. We're working to fix the problem as quickly as we can.
Wed 01/06/2011 at 10amResolved Problem in the Healing area
I have just tried again and this time I can neither send or receive messages via BT.   The window that appears after a few seconds is
Then a Mail Delivery Failure message returned to PegasusMail as follows:
Network or Protocol Error message window appeared with:-
"From:    Mail Delivery System <>
    To:    Self
    Subject:    Mail Delivery Failure.
    Date sent:    Wed, 01 Jun 2011 16:35:32 +0100
Delivery has failed on the enclosed message for the following
reasons reported either by the mail delivery system on the mail
relay host or by the local TCP/IP transport module:
   *** TCP/IP error while processing job ***
   A network error has occurred while WinPMail attempted to send
   your message. This error could be caused by many conditions,
   including the following:
     * The remote host may have gone down.
     * Your network may have been broken or gone down.
     * You may have a configuration problem in your WINSOCK.DLL.
     * If running on a SLIP line, you may have experienced a
       timeout (increase the value in WinPMail's Network Config.
       Dialog), or the phone line may have gone down or suffered
       from excessive line noise.
   WinPMail will requeue your message and try again later."
[*] Connection established to 217.12.13.134
>> 0038 220 smtp816.mail.ukl.yahoo.com ESMTP
<< 0021 EHLO [192.168.1.64]
>> 0032 250-smtp816.mail.ukl.yahoo.com
>> 0032 250-AUTH LOGIN PLAIN XYMCOOKIE
>> 0016 250-PIPELINING
This is different from the previous message I gave earlier.   It was working about an hour ago after the previous failure - very odd.
Rodney Fry
Recognised Expert
Message 9 of 13
Re: e-mail
The problem on the Status Page refers to web mail which is only part of the problem.
Only one of my @btinternet mailboxes is functioning at the moment, the other four are showing authentication errors; they were working fine this afternoon.
I'm aware that a number of other BT users are experiencing problems and not just local to me. I'm on Wokingham (0118) exchange with an Infinity connection and the connection is fine. It's just the mail that is being a pain.
Message 10 of 13
Re: e-mail
Not sure if things rings as true!!
 Sorry for the inconvenience.
You've stumbled upon an unexpected, temporary problem. Performing your action
again in a few moments will likely resolve the problem completely. If not, we
suggest you try re-launching BT Yahoo! Mail.
If the problem persists, feel free to contact
Customer Care about Error Code 17
Thanks,
The BT Yahoo! Mail Team
