Message 1 of 4
email account
I have just switched to bt broadband and want to access my email accounts with my last broadband supplier, can I do this using mail (on mac) and what are the settings ie. smtp or whatever? to set it up,
cheers m
3 REPLIES 3
Recognised Expert
Message 2 of 4
Re: email account
Yes, you can do it - but you'll need to ask your previous for the setup details.
Distinguished Guru
Message 3 of 4
Re: email account
cheers m
Hi., Welcome to the forums.
The settings will be the same as they were, except for smtp (ie. sending emails). You will need to do a thing called email verification in order to send via BTinternet.
See my shortcuts option 0e for details. However you will need to alter some settings on your Mac (what email program are you using ?).
Message 4 of 4
Re: email account
Seem to have overcome problem after call from bt as you say on your link need to change smtp.mail.btinternet.com, reenter password and away you go.
thanks
