Message 1 of 9
eratic connection
can anyone help
since having my internet upgraded from bt to infiniti the connection is very eratic , sometimes i switch on pc and no connection, other times i get connected , sometimnes i can reboot several timesc before it connects? very frustrated as old bt was fine
8 REPLIES 8
Message 2 of 9
Re: eratic connection
Are you connecting using an Ethernet cable, or wireless?
Message 3 of 9
many thanks - wireless
Message 4 of 9
wireless thanks
Message 5 of 9
@crescentunited wrote:
wireless thanks
Does it work if you use a direct Ethernet cable?
Message 6 of 9
i havnt got one here sorry
Message 7 of 9
Its going to be difficult to prove whether its actually your Infinity connection that is at fault, without plugging your computer directly into the home hub.
I am going to assume that its most likely a problem with your wireless devices disconnecting, so I will move this thread to the Other BB board, where most of the threads relating to wireless are located.
Message 8 of 9
thanks
Message 9 of 9
There are a number of help pages relating to wireless connections.
Here is a BT one.
http://bt.custhelp.com/app/answers/detail/a_id/38064/c/346
And here is one from my help website.
Wireless problems and things you can try, to resolve them
Changing the wireless channel is the first thing to try.
