Tech3
Message 1 of 68
error 6013 / VC019 BT has never heard of this error before!
Me again, after 2 weeks of trying different suggestions members have posted on trying to sought out silverlight, decided to contact BT through live assistance ! after telling him the problem, he asked if he could ring me ! i accepted and he rang within 2 minutes, he asked me to explain the problem again ! told him when i click watch now and pick either bt sport 1, bt sport 2, ESPN i get the same error code.
6013 unable to playback video
err:VC019
He asked me to hold the line whilst he checked ! after 2 minutes he said BT has never come across these errors before and put me back on hold whilst he checked past record's on this error complaint.
apparenly these error code's have never been reported before by any BT customer...As a result he offered to ring me back within 48 hrs with a solution ( we will see if that call happen's )
So if anyone is experiencing the same code's as i am ! i will repost once i have answers from BT sport tech team.
And on that note ! i have been trying to access BT sport but it says it is under maintenance !!
Anyone else getting the same message 21:14 14/08/2013
67 REPLIES 67
yongkuk
Message 2 of 68
Re: error 6013 / VC019 BT has never heard of this error before!
They are making up new errors 🙂
Message 3 of 68
Hi
I have set up bt sport fine on my laptop but I get error code VC019 when I try and watch it on the TV using the HDMI port. Are you using the HDMI output?
Tech3
Message 4 of 68
Hi andy brown.
Sorry mate i should have explained in detail in my post ! i'm trying to access BTsport via my computer. i visit my brother on a friday night for a few beers ( yum yum ) so i will try accessing BT sport on his computer, let's see what happen's on his system !!
codex
Message 5 of 68
hi tech3 i had the same problem with error code vc019 i suggest you download mosilla firefox browser go to bt sport home page from there it works fine there seems to be a problem using internet explorer.
Distinguished Guru
Distinguished Guru
Message 6 of 68
Some people have found they need to enable Silverlight in Internet Explorer. Tools > Internet options > Programs > Manage add-ons > make sure Silverlight is enabled (you may need to select all add-ons in the "Show" drop-down list).
Tech3
Message 7 of 68
codex
iv'e always use firefox, read past posts !!
codex
Message 8 of 68
hi tech3 if you are using firefox then. make sure silverlight is enabled in firefox
Tech3
Message 9 of 68
so tell me how to enable please ?
codex
Message 10 of 68
hi tech3 go to add ons then plug ins and see if silverlight is enabled.hope this helps
