Message 11 of 68
Re: error 6013 / VC019 BT has never heard of this error before!
LOL been ther done that, did all that 1st day of silverlight install
Message 12 of 68
hi tech3 sorry i could not help with problem but i will investegate this issue .
Message 13 of 68
Hi,
yes i have the same problem. But only on this pc. Laptop works fine so do others. This pc has a 40" monitor attached to it. Not sure if that makes a difference. Exactly the same error on FF.
Message 14 of 68
I mean it works fine on my computer until I plug the HDMI lead in then I get VC019 error. Don't what it means but may be some help if you were using HDMI monitor.
Cheers
Message 15 of 68
Re: error 6013 / VCR BT has never heard of this error before!
I decided to reformat my computer after finding missing paramators on the hard drive ! thinking this was the problem went ahead and formatted, after 2 hrs of installing everything thought ! i had it cracked, signed in to BTsport watch now on ESPN ! got the message unable to show due to resrictions with ESPN, YES i have solved the problem ! so i signed out then signed back in and went to BTsport 1....guess what !! the error code has changed from 6013 to 6025
BT you are realy starting to get on my nerves now, if you cannot sought out these codes refund all the money you are scamming from decent people.
Distinguished Expert
Message 16 of 68
Set your clock correct and 24 hour format
To say thanks for a helpful answer, please click the white star
Message 17 of 68
Please read my new post, im all set up with a link sent from BT.
Message 18 of 68
So it works?
Message 19 of 68
It's worked for me dude.
Message 20 of 68
hi tech3 what is this link then please share
