Distinguished Guru
Distinguished Guru
Message 31 of 68
Re: error 6013 / VCR BT has never heard of this error before!
That's helpful, Neil. Also, several people have reported in another thread that simply making sure Silverlight is enabled in Internet Explorer has done the trick. Worth repeating the path posted at Message 6 above:
Tools > Internet options > Programs > Manage add-ons > make sure Silverlight is enabled (you may need to select all add-ons in the "Show" drop-down list).
Moderator
Moderator
Message 32 of 68
Distinguished Expert
Message 33 of 68
@NeilO wrote:
Full URL for the tip I posted:
http://btconsemailmanagement.custhelp.com/app/mailmanagement/cs_mail2/template/silverlightforumtips/...
That link gives me this:
Fatal Error
Access Denied
Reason: Client address is not authorised.
To say thanks for a helpful answer, please click the white star
theplc
Newbie
Message 34 of 68
Re: error 6013 / VC019 BT has never heard of this error before!
Hi all,
I was having playback issues on all Silverlight-based streaming services and solved it with the following steps:
  1. Browse on your computer to “C:\ProgramData\Microsoft\PlayReady\”.
  2. Change the name of “mspr.hds” to “mspr.hds.old”. (In other words, you want to get rid of the mspr.hds file, and you are renaming it just so that you have a backup copy of it
Link to original solution:
http://mike-thomson.com/blog/?p=210
Tech3
Message 35 of 68
This is the txt i got from BT sport technical team.
Hi BT here.
we're sorry to here hear you're having a problem Watching BT sport online.
The problem relates to a Microsoft browser plug-in called silvelrlight.
Which the BT sport online player uses to protect against piracy.
if you get a silverlight error, we suggest visiting http://tinyurl.com/llk8xx2
for futher help and advice please call 0800 111 4567 this is the BTsport technical team help line.
I have checked the link and for some reason it is'nt working !!! strange because i used it only yesterday.
the other option is to go through your mybt account and at the bottom of the page you will see contact BT.
Click that and you have multipal option's, i went with BT infinity...then complaint's this will take you to a live assistance, put you detail's in, such as your name address and account number then make the complaint about silverlight not working on your computer, But make sure once you connect to an advisor you tell them the spec of your computer.
I,E operating system...memory...ram....graphic's card...upload and download speed !
This is how i got the link above to sought my problem out.
The other thing is ! if the link still won't work type it in your browser it should work that way.
Sorry i can't be more help but that is the route i took and it works for me....I truely hope thing's get soughted for you all.
If this has helped please click the white star on the left....Many thanks all
Message 36 of 68
Someone else managed to copy and paste it here http://community.bt.com/t5/Watching-BT-Sport-via-the-App-or/error-6013-VC019-BT-has-never-heard-of-t...
Tech3
Message 37 of 68
I have copied and pasted the txt from BT as you asked me to do , what more can i do ! rather than you posting other members links try ringing BT on 0800 111 4567 this is the BT sport support team
I urge everyone with the 60+ error code's to ring the number above.
STOP WAITING for someone to give you the solution to your problem ! i have done it and all works well for me.
man there are some lazy people about !!!
Message 38 of 68
It was the text behind the link that I requested. You failed to deliver, someone else did it instead.
You missed your chance. Get over it.
The answer is here http://community.bt.com/t5/Watching-BT-Sport-via-the-App-or/error-6013-VC019-BT-has-never-heard-of-t...
Tech3
Message 39 of 68
LOL i'm well over what ever you think i should be over ! hope the link posted works for you, even thought you never picked up the phone to sought out the problem yourself.
Message 40 of 68
After 3 hours of trying, the following worked for me in Windows 7.
1: Change time zone and then change back to London time.
2: Clear browser history
3: Uninstall and then re-install Silverlight
4: Install Firefox ( I was using Google)
5: Re-boot
6 :Log into www.btsport.com
7: Select Watch now / Watch
8:  The error message 6025 / VC019 still appears, but ignore and select continue
 Hey presto !
ps. apparently many people encountered problems today, when trying to tune in after the match had started.
