thewall58
Message 1 of 3
extra ethernet ports
I have a BT hub 6 and it has 4 ethernet ports i'm using 2 at the moment one for network cameras and one for my computer i'm wanting to get Sky Q and connect the boxes (3in total) to the hub is there away to do this, i know they are wireless but wireless connections in our house are intermittent.
2 REPLIES 2
gg30340
Message 2 of 3
Re: extra ethernet ports
Buy a network switch. The are very cheap and they come with various amounts of Ethernet ports so you will find one to suit your needs. You just plug it in and connect an Ethernet cable from the Homehub to it and you can then use the rest of the ports on the switch to connect as many devices as you have ports.
If you do an Internet search you will find any number of them.
thewall58
Message 3 of 3
Thanks GG thought there would be away round it
