pistolpete33
Message 1 of 15
faster?
does thus mean i should be able to get a faster connection speed?
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
2308 Kbps
0 Kbps7150 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 2308 Kbps
 For your connection, the acceptable range of speedsis 1000-7150 Kbps.
 Additional Information:
 Your DSL Connection Rate :3072 Kbps(DOWN-STREAM), 1083 Kbps(UP-STREAM)
 IP Profile for your line is - 2500 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 11.34:20.66:68.0 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit FAQ section if you are unable To understand the test results.
14 REPLIES 14
miket101
Message 2 of 15
Re: faster?
Hi welcome to the forums if you post all of your router stats someone maybe able to help 😉
pistolpete33
Message 3 of 15
Re: faster?
ADSL line status
Connection information
Line stateConnected
Connection time1 day, 9:56:43
Downstream4,544 Kbps
Upstream1,071 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.5
Latency typeInterleaved
Noise margin (Down/Up)12.3 dB / 6.3 dB
Line attenuation (Down/Up)45.0 dB / 21.2 dB
Output power (Down/Up)0.0 dBm / 13.1 dBm
Loss of Framing (Local)11
Loss of Signal (Local)1
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 4294967294
CRC Errors (Down/Up)788 / 2147480000
HEC Errors (Down/Up)nil / 0
Error Seconds (Local)486
dodgy368
Message 4 of 15
Re: faster?
Can it go faster? Yes, if the line stays stable the dlm will drop the snr(noise margin) down to 6db which will speed you up to 7-8mbit.
Wish there was a stickie telling how to tidy up internal wiring, would really help.
Guru
Message 5 of 15
Re: faster?
Some very useful stuff here ... if the DIY type.   😉
http://www.jarviser.co.uk/jarviser/broadbandspeed.html
dodgy368
Message 6 of 15
Re: faster?
RogerB, that's a great link, well presented and VERY easy to follow. 😄
Guru
Message 7 of 15
Re: faster?
You being sarco?      Smiley Very Happy
Seemed a good idea .....  it's all in there somewhere.   Smiley Sad
Jarviser was a good guy on the forum at one time.    Smiley Sad
The full monty is here .....  http://www.rob-r.co.uk/other/UKphonecatwiring.htm
dodgy368
Message 8 of 15
Re: faster?
Noooo, that **bleep** smillie... I typed : D, which should show a big grin/smile, not that stupid thing, sorry. 😉
Edit: what's with the smillies, the one on this post should be a smile, not a wink?!
Guru
Message 9 of 15
Re: faster?
They do take a bit of getting used to ....
That's why I use my own ... sometimes.  😉
dodgy368
Message 10 of 15
Re: faster?
Is that supposed to be a wink or a smile? 😛
just typed : P wonder what horror is gonna appear!
Hooray, I got one right!!!
